Originally posted by emoxristov
VLF MD (by Sascho - Varna)
the Way connected transistorsAttached Files
Does anyone have a picture of the connection of the diodes and transistors
Hello my friend, pcb circuit lets you take advantage of thanks to all
Sasa is presently here in the forum under the nickname scs
http://www.geotech1.com/forums/priva...o=newpm&u=9051
For now, no one, only Sasa.Originally posted by xycy View PostIs anybody made Slow M. detector? What are the results of it?
If you had decided to build a, easier for your DD coil. Sasa advice:
DD coil 260 mm diameter-7.2Khz frequency
L1=L2=110turns.
C7=220n
C9=100n|frequency|
C11=1MF
C4=33n
C5=33n|resonanse|
For more details contact Sasho's. You may be given a scheme with better resolution, where they will be visible to all elements...
Can somebody give more details about the TX coil of Slow M? What about 'comp' coil, how to build it?
Why 'will not be able'? What is hindering it?
What about russian circuit 'PI beta01'? Have somebody built it? It looks nice.
Barracuda is easy to build, detect 1 euro to 30 cm deep in the ground, slightly better than the Surf PI.
What do you expect to find at 30 cm depth? Necklace and earrings will not be able.
SM I have put for Surf Master
. It works in the wit sand but I need ~30cm depth in the ground. Also I don't like very difficult circuit just its difficult to make the PCB. Did you build S1 or Slow M. or Baracuda. Tell me please their performance. Which one would you recommend.
