Full m/lab SD2000 schematics
  • Hi! may be e-bay, https://eu.mouser.com/c/?q=tlc7m7, https://www.chipdip.ru/search?searchtext=tlc27m7 ?
    • pcb arrived
      pcb geldi iyi iş?ilik par?alar i?in bana şans dileyin andrei
      • Originally posted by Dayzil View Post
        • Do not use old parts, use TLE 2022 in place of TLE27m7 as is has faster settling time , greater bandwidth, less noise and lower power. And is much better, i have used this as a single supply buffer amplifier on the SD2000 .
          • May be TLC27M7?
            • if you install tle2022, will you probably need to change the amplifier harness?
              • TLE2022 may not be compatible, it is what is used in the GPX4500/5000 detectors, my bad. I had a re-chipped SD2000 but I sold it and now cannot locate my files.. I made some small sub boards with different chips, but like 8 years ago.
                  where is PCB file ?
                  plase upload PCB file.
                  • ​ What would happen if you did not connect that is to 8 pin cd40106 with 100R ?​I know it locks Tx, does it affect anything else?​ Is it possible to take the sample later or earlier after closing the tx signal?​
                      It allows the detector to use 1Mhz or lower frequency timebase, beware stretching out the TX below 900Khz as the mosfets will nearly start glowing in the dark.
                      • Originally posted by detectormods View Post
                        Thanks Peter, that means no smaller crystal than 1mhz​ ..
                          You can go lower in frequency but the output Mosfets will need to be upgrades to lower on resistance types.
                          • I read in the forum that the GP3000 series uses an LC oscillator controlled by a varicap diode to vary the frequency, I wonder if it would be possible to adapt it to the SD2000.
                            Here in my country it is difficult to get crystals of different frequencies to experiment.​
                            • Originally posted by Jose View Post
                              Stick one of these into it,
                              https://www.ebay.com.au/itm/29498808...Cclp%3A2047675
                              • Thanks Detectormods.
