DEEPERS
  • without tr6 value and oscilos there is not possibility to repeat the detector for you.
    no new winter project, you left without the lollipop present from Santa Claus.
    • It's strange that they use "TR" as the reference designator for a variable resistor. I guess it's supposed to stand for "Trimmer Resistor".
      It is normal to use "R" for all resistors.
      • I dont know why some members uses this forum to talk some things without importance, please if you dont have real information dont post here.
        By the way the Deepers 8at posted in geotech is correct and it work fine, I had make it and I am using for prospect. Deepers in all version are very good detectors. I had put details for making the autentic deepers hypersensitive coil in a thread started by me but it seems that someone dont take it seriously.
        Dont ask anymore for the deepers, they are good PI, good projects for make. I am sure better than Barracuda, surf Pi, GoldScan etc, etc, etc because I had been built the Deepers 8 and testing too Deepers 7, Deepers 2x1 and X5.
        Read Deepers Thread Started by my MFC.
        • Who is clear about the scheme of this device deepers 8
          https://www.up4.cc/downloadf-152356269094551-rar.html
          • The Deepers 8 from Geotech is correct. I have one make by myself and I am using for prospecting. I use the correct search coil 40 x 20 cm elliptical shape of computer network cable 8 color wires made by me. I will make a X5 as soon as possible.
            • hello mfc deepers x5 please tell me why you do not send the schema
              • do not send. first of all a bare schematic without full information is only lack of the information.
                let Deepers 10 DD being last in the forum, from all deepers. also x5 may be use for business.
                • why did not you send KT315
                  • MFC please i want to make deeper x8 help as put the file of deeper x8 that work well soon . My regards friend
                    • Originally posted by soylu View Post
                      I DO. if i promised something i make! everybody will get the PCB from me.
                      • Will your pcb be two side or one?
                        • two sided. it will be almost a copy. but to revision 3-4 i will change layout to more optimal view.
                          original board is huge in size, i do not like such size.
                          • Hi all friends . Please put the full file of deeper x8 that works well my regards
                              I agree. Original board is much space available. More compact two side pcb will be great.
                              I've been searching for deepstar schematic. Do you have?
                              • Originally posted by sbalio1 View Post
                                a problem of those people they always begin something optimistically but to end they are looking like they got asfiction.
                                i do not see file of deepers x8 that works well. no oxygen, no pics of high resolution of desoldered board with BOM file, full lack
                                of the data. https://dfiles.ru/files/me3gubuk7?redirect
