DISCRIMINATING PI
  • DISCRIMINATING PI
    Here is the discriminating signal processing circuit of the TINKERERS_V1.
    It has been breadboard tested and gives good results.
    The sensitivity is good and the discrimination is to the full depth of detection.
    Any comments, specially on ways to improve are most welcome.
    Tinkerer
    Do you have a higher resolution version that you can post?
      Tinkerer, new release info on Pulse Devil Nemesis. had you read this?
      PD has the discrimination ability...
      http://members5.boardhost.com/MetalD...253893265.html
        Tinkerer
        Hi TINKERERS, in to this schematic where is TX coil or Transistor.
          Tinkerer
          I say congratulations if you made a successful discriminating PI detector! Great job! I hope you make a document of your project and post as file.
          -SB
            TINKERER_V1 DISCRIMINATING PI
            Hobbes,
            attached are the EAGLE files.
            This is a work in progress and the help of all of you is very welcome.
            It would be nice if we could kick the EAGLE files around a bit, each one improving things a bit.
            Tinkerer
            Hmmm ... that did not work. The .rar file did not want to upload.
              Discriminating PI
              kt315,
              thanks for the feedback.
              Yes, I know about the PULSE DEVIL from David Emery.
              Allan Westersten also has a discriminating PI in the works that should come out soon.
              The TINKERERS_V1 is way behind, but with all of yours help, it can become the
              DISCRIMINATING PI for all the tinkerers of the world to tinker with.
              Tinkerer
                DISCRIMINATING IB-PI
                The TX part is here:
                http://www.geotech1.com/forums/showthread.php?t=15683
                There is much more information there, about the coil, power supply etc.
                There are also lots of oscilloscope pictures of the signal, discrimination etc.
                http://www.geotech1.com/forums/forumdisplay.php?f=53
                Tinkerer
                  ok , thanks Tinkerer
                    Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd tif txt zip
                    It appears that "rar" files are not allowed.
                    Try again with a "zip" file as above.
                      Hi Helikeon,
                      attached are the EAGLE files of the Signal processing circuit in Zip. I hope this works.
                      I will upload also the TX files in EAGLE.
                      Tinkerer
                        Hi TINKERERS, where is .Hex Software for PIC(mcu) and PCB.
                          TINKERER_V1 DISCRIMINATING PI TIMING SCHEDULE
                          I posted the timing schedule and Hex file at http://www.geotech1.com/forums/showt...0826#post90826
                          I am working on the PCB. You are most welcome to design a PCB and post it.
                          This is supposed to be a project where everybody contributes.
                          Tinkerer
                            Hi Helikeon,
                            Tinkerer
                            Hi Tinkerer,
                            Yes. That was successful.
                            Thank you.
                              Higher resolution RX
                              http://ultrashare.net/hosting/fl/6c4141fe0b/Tinkerer_RX
