Originally posted by Gervm
View Post
tr metal detector
It`s more liked on usual VLF IB metal detector. With the same success you may use TR coil construction with any detector of this type. I prefer "hear what I`ve transmited". For it several reasons. Power of transmiter may be medium or low but gain of amplifire must be high and the higher the better. Also on low frequency I use signal compensator to reduce leftover signal from TR coil. I don`t see it here so I think - It will be very difficult for this detector to find auto car (large target) at distance 3-4m.
This deppend of size of the 2 box too. I've seen a 2 box with 3 mm aluminium wire in coil, transmitter push-pull BD135-136. This detector is carry by 2 persons due the weight, but depth is more than 5 meters for big objects. Now, consumption is high and "out the regulations". Excess of sensibility in receiver can be bad, causes of inestability, you must found best point.Originally posted by Gervm View PostIt`s more liked on usual VLF IB metal detector. With the same success you may use TR coil construction with any detector of this type. I prefer "hear what I`ve transmited". For it several reasons. Power of transmiter may be medium or low but gain of amplifire must be high and the higher the better. Also on low frequency I use signal compensator to reduce leftover signal from TR coil. I don`t see it here so I think - It will be very difficult for this detector to find auto car (large target) at distance 3-4m.
I also saw similar detector with two operators. It was early russian bomb detector. But now it possible to build simple and cheap device with the same parameters by using opamps. I can draw circuit that designed several years ago but I need time. It was "wet" but worked enough stable.
Maybe. But here sometimes a couple of many ICs can't replace few transistors. I think that 2 box must be "crude" type...Originally posted by Gervm View PostI also saw similar detector with two operators. It was early russian bomb detector. But now it possible to build simple and cheap device with the same parameters by using opamps. I can draw circuit that designed several years ago but I need time. It was "wet" but worked enough stable.
