  • kadir6141
    @Carl:
    Click image for larger version  Name:	Q4.jpg Views:	178 Size:	506.3 KB ID:	421062Click image for larger version  Name:	Q4_Q5.jpg Views:	176 Size:	846.6 KB ID:	421063Click image for larger version  Name:	Q4_Q6.jpg Views:	175 Size:	767.1 KB ID:	421064Click image for larger version  Name:	Q4_Q6_Q5.jpg Views:	178 Size:	880.1 KB ID:	421065
    Click image for larger version  Name:	Q4_Q7.jpg Views:	174 Size:	758.8 KB ID:	421066Click image for larger version  Name:	Q4_Q8.jpg Views:	175 Size:	735.7 KB ID:	421067Click image for larger version  Name:	Q4_Q8_Q6.jpg Views:	176 Size:	752.1 KB ID:	421068Click image for larger version  Name:	Q4_Q8_Q7.jpg Views:	178 Size:	749.7 KB ID:	421069​​
    Hello Mr. Ivconic, how can you see all the timings at the same time with an oscilloscope?
  • GeoMax
    The LT1114 in the PDIP version (Truehole) is obsolete and is no longer recommended for new designs. However, the SMD version of the LT1114 will continue to be produced.
  • eduardo1979
    Originally posted by Emersonpaz View Post
    LT1114 seems out of stock is there any replacement?
    At mouser elecinics they are available.
  • Emersonpaz
    Originally posted by eduardo1979 View Post
    Why don't you make the GS-5?
    In my opinion it is a better detector than the GS-4.
    In the past I made a LITE version of GS-5 and it worked very well.
    My LITE version has the identical time base as TDI SL.
    The VCO is very nice, because it has a CD4046.​
    https://youtube.com/shorts/2tXTbySBUD4
  • ivconic
  • Jose
  • pito
    Voltage on pin 5 ?, how much is changing voltage on pin 6 when turning potentiometer 50k ?
  • kadir6141
    it is changing on pin #7 ?
    No
  • pito
  • kadir6141
    To see the voltage changes on pin no. 8, the voltage on pin no. 10 must change slightly below or above the voltage on pin no. 9, in your case you won't see this because the voltage on pin no. 10 is lower than 0.06 mV, check the circuit , set pin #10 to -15mV and adjust the voltage to "0V" with a 50k potentiometer, you should observe the voltage change on pin #8.
    Hi. Mr pito The voltage on pin 8 does not change constantly. -4.20v to -4.17v
  • pito
  • kadir6141
    Voltage on pin 9 ?
    hi. 9 pın - 06mv
    10 pın -15mv
  • eduardo1979
    Originally posted by algan View Post
    is that correct transistor to integrated CD4066 pin drain connected to pin 1 gate to pin 2 and source to pin 13 i want to modify your circuit on GS5-LITE
    The CD4066 is a bilateral switch, so the order of the pins does not matter. You just have to take into account the CTRL pin that must be connected where the JFET gate goes.
  • algan
    You could try to make a modification, replacing the J112 with a CD4066. The bad thing about all that is that you have to do it with cables and that is not good, because the cables generate noise and right there the noise is of no interest.
  • pito
    Voltage on pin 9 ?
