Originally posted by tuntunlin
To modify the pulse width, you need to change the value of resistor R13, which is currently 6.8kΩ. You should replace it with a 10kΩ potentiometer in series with a 2.2kΩ fixed resistor. With the potentiometer, you could adjust the pulse width below and above 100µs. The wire I used to use for my coils was 24AWG stranded wire with PVC insulation. Now I use Litz wire for all my coils. You should use graphite paint instead of aluminum foil for shielding your coils. The coaxial cable is also very important, as its capacitance can significantly affect the detection of low-conductivity targets. If you lower the pulse width to 80µs, you could increase the frequency to 3kHz. What you're experiencing with the coils, I believe, is due to their high capacitance, or the high capacitance of the coaxial cable. I'd like to see an oscilloscope image showing the measurement at pin 6 of the NE5534. That way we can see the waveform and draw some conclusions.
Eduardo,
I would like to know which component(s) need to be changed in order to adjust the pulse width from 100µs down to 80µs.
Thank you, Eduardo. I appreciate your explanation.Originally posted by eduardo1979 View Post
Hello. The detector works correctly with any delay level, but if you change the delay, for example from 10µs to 15µs, you always have to readjust the ground balance. The delay is a feature of the detector that helps eliminate certain low-conductivity non-ferrous metals, such as aluminum foil, etc. If you want to search for gold nuggets, I recommend setting the delay to 10µs and properly adjusting the ground balance. If your intention is to search for jewelry on the beach, you should use a slightly higher delay, such as 15µs, since the effect of salinity could affect the detector, causing it to emit false signals continuously. Also, on white sand beaches without mineralization, you could detect with the ground balance at the minimum level, thus gaining a little more depth for small gold targets. The frequency I used was approximately 2.8 kHz, and the TX pulse width was 100µs. Obviously, with a pulse width of 100µs, the IRF740 heats up more and power consumption increases. I recommend a pulse width of 80µs to avoid all these problems. A very high pulse width is useless if your coil saturates. To answer your last question, I'd like to know if there are any hot rocks in your search area. If there are, you'll have to avoid them to search for other targets, but by increasing the ground balance level, you'll notice a slight loss of depth. Keep in mind that this detector doesn't discriminate between ferrous and non-ferrous metals; instead, it discriminates based on conductivity (high and low). If you want to learn how this detector actually works, search online for the instruction manual for the Whites TDI SL detector; that will greatly help you understand the true operation of the GS-5.
Based on my current tests, I have found the best results with the damping resistor at 680Ω when using an oscilloscope. I tested both a small coil and a large coil (both 300µH). The small coil works best at a 15µs delay, while the large coil works best at a 22µs delay.
My question is: what could be the possible issues preventing a single coil from working across all delay ranges?
The 470Ω damping resistor I mentioned in my previous post was a value I adjusted while using aluminum tape wrapped around the 300µH coil. Now I am using 25 SWG coil wire wound to 300µH. The fact that it only works at a fixed delay rather than across all delays—could this be due to the wire gauge size?
The current DC resistance of my coil is approximately 1.6Ω.
Therefore, I would also like to know what wire gauge size you (the teachers/mentors) are using for your coils.
My step-by-step adjustments so far are as follows:
· Damping resistor: set to 680Ω (optimized with oscilloscope)
· Frequency: set to 2.8 kHz
· NE5534 offset: adjusted to 0V DC
· Supply voltage: 14.5V
I am looking forward to your answers. Thank you all very much.
Hello. The detector works correctly with any delay level, but if you change the delay, for example from 10µs to 15µs, you always have to readjust the ground balance. The delay is a feature of the detector that helps eliminate certain low-conductivity non-ferrous metals, such as aluminum foil, etc. If you want to search for gold nuggets, I recommend setting the delay to 10µs and properly adjusting the ground balance. If your intention is to search for jewelry on the beach, you should use a slightly higher delay, such as 15µs, since the effect of salinity could affect the detector, causing it to emit false signals continuously. Also, on white sand beaches without mineralization, you could detect with the ground balance at the minimum level, thus gaining a little more depth for small gold targets. The frequency I used was approximately 2.8 kHz, and the TX pulse width was 100µs. Obviously, with a pulse width of 100µs, the IRF740 heats up more and power consumption increases. I recommend a pulse width of 80µs to avoid all these problems. A very high pulse width is useless if your coil saturates. To answer your last question, I'd like to know if there are any hot rocks in your search area. If there are, you'll have to avoid them to search for other targets, but by increasing the ground balance level, you'll notice a slight loss of depth. Keep in mind that this detector doesn't discriminate between ferrous and non-ferrous metals; instead, it discriminates based on conductivity (high and low). If you want to learn how this detector actually works, search online for the instruction manual for the Whites TDI SL detector; that will greatly help you understand the true operation of the GS-5.Originally posted by tuntunlin View PostGreetings to all the brothers who have successfully built the GS5 Lite.
I would like to ask you with respect.
On the GS5 Lite, does it work well across the delay range from 10µs to 25µs, or does it only work at a specific fixed delay setting? I would like to know.
Does the ground balance function properly throughout the 10µs to 25µs delay range?
I would also like to know what frequency and pulse width settings you are currently using.
Additionally, after the ground balance rejects hot rocks, have you observed any improvements in target discrimination and sensitivity?
Please kindly reply. Thank you.
- Likes 1
Greetings, Emerson Paz.Originally posted by Emersonpaz View Post
If you have a clear photo of your board with the ICs mounted and everything looks correct, it seems like you might be using a counterfeit IC.
After you have fully built your GS5 Lite, could you please share your data and results as well?
I would like to know: does your unit work well across the delay range from 10µs to 25µs, or does it only work at a specific fixed delay setting? Also, does the ground balance function properly throughout the 10µs to 25µs delay range?
Greetings.Originally posted by David222 View Post
Hi. I've been working on this circuit for about ten days, and I exactly built Eduardo's schematic. But when I set the frequency knob to 1k, the 7912 regulator gets overly hot. When I change the knob to 25k and use a frequency of 1300Hz, the regulator voltage fluctuates by 5 volts. The VR3 potentiometer really doesn’t do much. The loop resistance is 2 ohms and its inductance is 440 microhenries. If I use a 25k knob instead of 1k, the heating problem is solved, and it can detect a 3 cm coin at 30 cm. But the GEB is off and it also detects broken ceramics. When I turn on the GEB, the board’s sensitivity drops drastically. Overall, this circuit wasn’t what I expected and it can’t really work in the field.
Because I am not satisfied with the current op-amp I am using, I have ordered an authentic/genuine NE5534. Once it arrives, I will test and verify it, and then share the results and data. I am also still in the process of testing. Thank you to all the teachers and mentors on the forum.
Hi. I have seen these. And Jose said that this circuit needs some changes, but the changes are stated in a scattered manner. I have read this thread more than 4 times. I apologize for the bad English. Thanks for the file and the effort you put in. I thank all the friends present in this forum for their efforts.Originally posted by Ruben2000 View Post
Hi David!
These are José's PCB files. [ATTACH]n450564[/ATTACH] [ATTACH]n450565[/ATTACH]
Hi David!Originally posted by David222 View Post
Thanks. Yes, it's different. I have seen José's circuit films. His GS4 works much better than the GS5. But unfortunately, its PCB file is not in the forum. Or maybe I can't find it. I have read these 48 pages three times, but I didn't find anything.
These are José's PCB files. GoldScan 4 Yerleşim Planı (1).pdf GoldScan 4 PCB (4).pdf
- Likes 1
Thanks. Yes, it's different. I have seen José's circuit films. His GS4 works much better than the GS5. But unfortunately, its PCB file is not in the forum. Or maybe I can't find it. I have read these 48 pages three times, but I didn't find anything.Originally posted by kt315 View Post7912 regulator pinout is NOT as 7812. look in google.
Hi. I've been working on this circuit for about ten days, and I exactly built Eduardo's schematic. But when I set the frequency knob to 1k, the 7912 regulator gets overly hot. When I change the knob to 25k and use a frequency of 1300Hz, the regulator voltage fluctuates by 5 volts. The VR3 potentiometer really doesn’t do much. The loop resistance is 2 ohms and its inductance is 440 microhenries. If I use a 25k knob instead of 1k, the heating problem is solved, and it can detect a 3 cm coin at 30 cm. But the GEB is off and it also detects broken ceramics. When I turn on the GEB, the board’s sensitivity drops drastically. Overall, this circuit wasn’t what I expected and it can’t really work in the field.Originally posted by tuntunlin View PostGreetings.
My GS5 Lite is now working well. The previous issue was due to the PCB not being a true two-layer board as per the original design, but rather a single-sided PCB layout, combined with a counterfeit NE5534 IC and insufficient grounding, as well as unnecessarily long trace paths. Now the problem has been resolved.
Instead of using the NE5534, I have substituted it with an LF351. I have applied offset adjustment to pins 1 and 5 of the LF351. I am using a 300µH coil with a 470Ω 5W damping resistor, and the waveform at pin 6 of the LF351 is correct.
I am currently testing the device. At a 10µs delay, the ground balance does not match properly; it only works correctly at a 23µs delay. The low-tone/high-tone discrimination is functioning correctly. However, what I need is the 10µs delay.
I have also tested with a 250µH coil, and the device still works correctly at the 23µs delay with proper ground balance and tone discrimination.
Frequency: 3 kHz
Pulse width: 100 µs
My current question is: what adjustments or changes are needed to make the device work properly at a 10µs delay?
Please kindly provide detailed technical information and support, respected teachers.
Greetings.
Frequency: 3 kHz
Pulse width: 100 µs
Alright no need to be nervous upset.Originally posted by Orbit View PostI'm amazed that a nearly registered geotech forum user with 17 posts asks so much. I wish you luck in making a TDI, first you wrote that you intend to make a TDI and in the next post you have neither a schematic nor a device that you can redesign. So again the old new member. Who is actually there to possibly get some data that is not available on the forum and that no one will even put as valid. All the best happy work.
I wish you success too.
