  • ABDW9
    Hello Jose
    Now only key "RESET" just is not working??
    All the problems that I have a solution
    Thanks Only Jose
  • Jose
    ABDW9
    Sorry, do not understand the question, please try again in a timely specifying each question.
  • ABDW9
    Originally posted by Jose View Post
    Hello ABDW9
    This is the way I set my GS4 and works well:
    Do you have to be a leg to adjust RV5 U13 at 0 V instead of the leg 7?
    "Yes !!!"
    Adjusted R8, to 0 volts on pin "6" of 5534, with the coil connected, away from all metal.
    All adjustments in position 2, "all metal", follow the steps outlined above in post 102.
    After adjust RV7 to 0 Volts in pata "8" of U13 C, Change SW1 in position 1, "OFF", and adjust RV6 to 0 volts again in pata "8" of U13 C.
    Check iron rejection mode is "SELECT 1" No. 3 of SW1.
    Prepare a video later.
    Jose
    Thank you my dear brother Jose
    I've been in a hurry something
    But I realized that I should be a little bit slower Instead of Ask Ali Mrajat a all previous settings even harder on something you'll ask
    Please excuse me
    'll Try to review all previous settings
    I and so far has reached the stage quite a bit
    Thank you brother Jose
    Regards Abdo
  • ABDW9
    Peace to all of you
    We have worked hard to treat the problem of the reset key, but I did not gain a thing
    I also realized from Q10, and D11 are all good
    Please explain to me where the problem can be
    Thank you
    Abdo
  • Jose
    Originally posted by pigeon View Post
    hi all
    it is project correctly
    thank you
    best time
    P.
    [ATTACH]24222[/ATTACH]
    Hello Paloma
    I had much trouble PCB with this due to noise, I think it is a design problem.
    I do not recommend it!
    Jose
  • pigeon
    hi all
    thank you
    best time
    P.
    GoldScanPCB.zip
  • Jose
    Thanks Lucafa
    I have no experience with the graphite tape Scocht only No. 24 for pulse detector coil, and aluminum tape for detectors IDX-Pro
    Here where I live, not achieved graphite paint. I have graphite powder and want to experience mesclando with acetone or other adherent.
    Real good your advice, thanks.
    Jose
  • lucafa
    Thanks ABDW9 and jose.
    Wery well.
    Good job jose.
    One question, have you tried to use graphite spray for the screen?
    Metal grid great screen with a reduced signal transmission and reception.
    If you use graphite, 10 ohm cm have a perfect shield, but not metal.
    Use in this way.
    Building coil as you want, paper tape wrapped around the coil, 1x1 cm piece copper (recovers from pcb) with welded wire 5 or 10 cm, glued with hot glue a piece of copper tape, spray graphite thin layer and wait until dry. Measure resistance per cm, if not 10 ohms make another layer of spraying.
    When good results, connect the screen to shield wire coil.
    The 10 ohm as a guideline, try resistivity is high and excellent result.
    For example VLF coils have resistivity screen from 3 to 7 kilo ohms.
    regards.
  • Jose
    Originally posted by lucafa View Post
    Jose.
    Thank you very much for your explanation.
    I imagined strange things, while he was a simple thing .
    A question, you can measure how diameter of only one conductor and how many individual small wires is composed ?
    I want to be sure to use the same material to compare the results.
    If you write me also cable serial number would be perfect.
    Regards.
    Lucafa
    The cable is known as UTP or CAT5 for computer network, consists of four twisted pairs, eight in total, and the diameter of each conductor is 0.5mm.
    Cat6, the driver is alrrededor diameter of 0.6, with a little more insulation, the two works well. Cat5 is easier to work for its lower section.
    Attached is a photo, where observed the cable insulation with Scotch tape No. 24, makes a shield.
    In the photo is a single coil, you must perform two coils with 2 laps each with diameters of 20 and 30 cm., connected in series as shown in the post above.Click image for larger version
  • ABDW9
    Welcome back lucafa
    Number of small individual wires 7
    diameter of only one conductor about 0.05 cm
    Thanks for helping me
  • lucafa
    Hi all.
    The L4 is 330 millihenry NOT 330 microhenry for piezo use.
    If no correct value defect is low sound.
  • lucafa
    Jose.
    Regards.
  • ABDW9
    ABDW9
    Where problem?
    If new construction controls FET J113 when mounted correctly.
    Check pin 8 U12C, if VOUT is always ZERO, control calibration setting or TL064 failure.
    Check fault on DIODE OA85 (gate Q10 and GND).
    Check proper functioning RESET button.
    Regards.
    Thank you very much
    Brother lucafa I will review these
    You greetings
  • lucafa
    ABDW9
    Where problem?
    Regards.
  • ABDW9
    Peace to all of you
    I have been asked several questions, but I did not see any answer
    And now I have only one question
    I have a problem in the RESET key does not work Is it possible to explain where the problem
    Knowing that the device works perfectly ..
    Greetings Abdo
