I created a Gary pulse 1, hoping to get your help. I changed the 2N3819, but the circuit is detected low. I already have two pieces of the same circuit board, they generally work the same.
chemelec help me
I set the IC9, 0. 5 V
YOU say, Connect a Voltmeter to Pin 6 of IC9 and Note the Voltage Reading, Now Bring a large piece of metal Near the coil, and this voltage should go Higher [Possibly up to 2 Volts.)
I Now Bring a large piece of metal Near the coil, only 0.7 volts
Maybe a Poor Coil?Originally posted by yhl View PostI set the IC9, 0. 5 V
hello
I was only 0. 5MM line. This parameter can it?Attached Files
First, I Don't understand the Language on your Drawing.Originally posted by yhl View PostI was only 0. 5MM line. This parameter can it?
What is 0.5MM line?
Your Wire Size?
0.5mm is about 24 AWG
0.3mm is Even Smaller. But Not sure why that is on the Picture.
And If that is what your using, its a Bit Small.
I Recommend 20 to 22 AWG.
Why Did you make a Shielded Coil?
I Don't recommend a shielded coil on my detector.
At least Not for General Detecting.
hi
Yes I know. This picture is I found. I have a folder, you can see.
What is a Polish website.
I did not do the coil, I just made a 0.8 mm. 30 laps. 28 cm of the common coil.
http://www.elektroda.pl/rtvforum/topic1056104.htmlAttached Files
My Flat wound Radial Coil has an 8" Outside Diameter, with 38 turns, 20.5 AWG.Originally posted by yhl View PostDo you detect a coin 30 cm, what is the frequency used? coil is 34 8-inch flat circle 0.8 mm cable?
Inductance is 402uH.
Frequency is 100 Hz and Sightly better results with 1000 Hz.
I can Detect a "CANADIAN Quarter" at 30cm. (This is Made with NICKEL Metal.)
I can Detect a "US Quarter" at 25 cm. (This is Made with ZINC or Copper Metal)
(Both these QUARTERS Measure about 0.95 Inches in Diameter. (23mm Dia)
The Frequency is 100 Hz but get Sightly better results with 1000 Hz.
WHAT IS THE COIN YOUR USING?
AND WHAT TYPE of METAL is it?
And WHAT DIA?
hello
I can not express what I mean, the U.S. quarter (zinc I believe) in air distance of 10 inches
Is the piezoelectric speaker. Drop the sound or scream?
Detected when the coin is that few inches screamed?
I want to know
coins Screaming in the few inches?
hello
VR5 can increase the sensitivity of it?Attached Files
