PIM-2 Digital Metal Detector Project
What programmer should be used for programming the chip, if you can set the schematic here on the forum that you can make at home. Some simple scheme, as well as the process of entering input files into the microchip that file must first enter the hex or drugi.I want to know whether this is a demo version which include some 500 valid
the device. What program should be used for programming.Thanks in advance
What programmer should be used for programming the chip, if you can set the schematic here on the forum that you can make at home. Some simple scheme, as well as the process of entering input files into the microchip that file must first enter the hex or second.I want to know whether this is a demo version which include some 500 valid the device. What program should be used for programming.Thanks in advance
Nice work elbombaci,
but you're not clear about required specs. For starters, what are coil requirements? what are the needed inductance/resistance values?
Also, your schema shows you using an Atmega8, but your web site has pictures of programmed Atmega328s: a Much newer chip, with different requirements. Is your public schema your latest design? or is your latest design the retail version?
Also, what are your fuse settings?
Unless you specify these requirements, not many users will be able to get your detectors working.
Hi elbombaci
can you change your md mosfet to bup314 ?
it used in miner 4 .
miner 4 is not a good md its hex design to not work deliberately
but bup 314 is a good component and in my mind it must be a good project for you
change your md coil driver and see it change very strong tx power
best regards
freedan3d
[email protected]
Hi to all.
@freedan3d
I have not bup314 now. I will try to use bup314.
@6666 and johnandles
This links are two photo about coil with cat5 or cat6 cable:
@Miata
I attached last version all documents here. But you follow this link for updates. You join to see attached documents in lugatek forum.
Elektronik donanim, gomulu sistemler ve ileri seviye yazilim cozumleriyle endustriyel donusume onculuk ediyoruz.
I am sorry for my bad English.Attached Files
- Likes 1
