Surf PI Pro
  • ApBerg
    Remove all IC's but leave the ICL7660 on the pcb, then check how much current the pcb is taking from the battery ,must be less then 40 mA ,
    and check if you have + 5volt and ca. -4 volt on the IC sockets look at the color bmp
    Tell the results ?
  • paku
    Ok this Is Clear Picture
  • seadoggy
    paku check your C5 220n and C6 220n,i can see in your image above you make direct connection whit tin or copper,pls clean board and put clean image
  • paku
    I cannot make the sound gone with the tresh pot,
    can you show me sample of tresh pot connection and I removed the NE5534 but it still make sounds
    I use 9 volt battery,
    yes T1 i use 2N3906
  • ApBerg
    Hello Pau,
    Looks nice... can you tell how much current the circuit take's from the battery ?
    Can be your tresh- tune pot is wrong (connected)..... you can not make the sound gone with the pot ?
    If you remove the NE5534 from the board is the sound gone ?
    Look also at the pcb side, at the caps under the LM358.. looks like a wire from a cap is making connection to a other cap.. cut the wire's fot the caps a little shorter
    T1 is a 2n3906 ? if you use an other one check the ebc connections.
    Succes
  • paku
    This Is My Board
    did i make mistake
  • paku
    I Have Finish My Surfxx but when i put the 9v battery i just get only beep long beep
  • paku
    Can I use a potentiometer at trimpot
  • paku
    Ok Thanks Brother
  • joop
    You need to experiment
  • paku
    so if i put that 3.3k resistor its will work on my right coil?.
    or i must use the 5k trimpot to set that coil
  • joop
    It will work okay with a 3k3 resistor... When using a trimpot you can change the dutycycle of the 555 which modifies the pulse width. Depending on your coil you can set the pulse width so you have both the lowest battery current and best depth range.
  • paku
    so that is not 3.3k Resistors right
  • Carl-NC
    It's a trim pot.
  • paku
    somebody please help me explain about R2 is 5K (3.3) What is that mean
Name:	SurfPro1 - Copy.jpg
