Surf PI Pro
  • I am slowly putting the board together using the latest PCB made by ahcene2035 with NE555 instead of ICL7660 (the LT1054 is quite expensive :-" ).
    The only thing I don't understand is how I trim the R2 pot (the one that sets the time of TCL555). After what frequency I am looking after? Or I must trim it based on the best detection range?
    • Just because pi is taking so weak I did. 20-25cm at most. How to get deeper.
      Sadece Pi'nin ?ok zayıf aldığı i?in yaptım. En fazla 20-25cm. Daha derin nasıl.
      • hai ... semua ... walaupun sudah terlambat ... tapi saya sudah mencoba membuat pi surfp yang bagus dan bagus tanpa kendala ... bahkan dengan menggunakan komponen seadanya ... terima kasih kepada semua teman yang telah membantu wujudkan ... terima kasih lagi
        • Originally posted by kang agus View Post
          and make your posts is English.
          • hi ... everyone ... even though it's too late ... but I have tried to make a good and good pi surf pro without any problems ... even using makeshift components ... thanks to all friends who have helped make it happen .. . Once again, thank you
            • Hello, do you have the modified pcb in PDF format to be able to print it? Can you post it in the forum? Thank you
              Carlos
              • Surf PI Pro
                delete
                • Can someone repost good working pcb and layout for Surf PI Pro?
                  • there is such run-ahead-the-fastest-horse guy name 'ApBerg'. sometimes he does something sometimes disappears to eternity.
                    seek his long-board.
                    • a board on ebay https://www.ebay.com/itm/SurfPI-PI-D...8AAOSwgv5ZPuqs
                      129 sold. good boy.
                      • a board costs $7,49, it 's expensive !
                        • Originally posted by Floki View Post
                          USSR had dead!
                          • Hello fellow enthusiasts, I have done my suf xx, And I am happy with his work. My question is, would hearing sensitivity be changed if the output stage for the candlestick was done, like PI Polonaise, or like with a Delta pulse , using a single NE555 ic?
                            I apologize for English, I use google translator
                            • Could someone give me the pdf pcb the surf xx_ ne555 file. Thank you.Carlos
                              • Hello Carlos
                                Attached Pdf surf 555
