thanks zomby
but i have some problems with russian language
i think i can see what you mean
here latest video
http://www.youtube.com/watch?v=70wtA...ature=youtu.be
regards bernd
redesign of tiny from pulsdetektor.de
did you mean i should use irf740 instead of mtp without any other changes?Originally posted by zomby View PostПробвай IRF740
looks good low on resistance so more power for coil - but no other protection needed?
should add one bidirectional Suppressor Diode (1.5KE400CA) parallel to coil
greetings bernd
hello all
i need help to redesign a pi detector layout.
is the german "tiny" from www.pulsdetektor.de
the design is from 2002 but is still a good beginner detector with a lot
of modifacation option.
im not 100 percent sure and able to do redesign.
but what i want is change Q1 MTP2P50E (PMos/500V) as replacemant
the layout should take a irf9640 plus two biderectional supressor diodes
another change could be to change U2 LF357 to another one, lf357 is out
of production and hard to get or very expensive.
i would be nice if someone could do a new layout
with new Q1 plus diodes
changing u2 is a task for later is hard to find a substitute.
regards bernd
Tags: None
