My Digital Pulse detector Delta Pulse 3
  • pigeon
    Originally posted by jap View Post
    [ATTACH]22362[/ATTACH]
    Frequent questions for DP3 ver3 and easy board was divided into parts as schematic:-
    1 - part of the coil and power.
    2 - part Charger and can not mounted it.
    3 - part programmed controller + keyboard + audio{SP} out.
    4 - part GLCD and control.
    5 - part scope and its components.
    6 - part determine the type of metal and match between the signals used by pic.
    7 - part of a normal delta pulse .
    I've put all the notes in every part of the answer to all questions.[*]-dEMO HEX =~ver3 used only in ver 3 pcb.
    -start test with coil 40cm , 3~4 ohm,400~500uh.
    -Must use keyboard sw1~5.
    -follow measure at points as schematic & PDF .
    -adj TR1 Will help in setting.
    -all value of R,C are All worked and change values for improvement.
    -All value of R=560 will changed later to improve performance.
    -All value of R of U2,D6 Can be modified to obtain the best results.
    -Most problems of choose different types of GLCD and followed connection method.
    -R43,37,40 Changed for the relation for GLCD[part 4].
    -in case not use Charger ,can use sw on/off in P3[part2].
    -all C 100n is mk type.
    -There are important components in the function, such as Q3,4=2n7000,Q6=BS250,D4=LF357,D6,Q5,Q9,U1.
    -Responsible for higher sound both T14,R79.
    -Responsible for the delay in the start vd12, C22,C24,C28.
    -The difference in results is due to the difference in components and quality of connections of the pcb.
    best time
    j.
    hi jap
    thank you very much................
    baraka allah fik
  • jap
    best time
    j.
  • jap
    This talk is unscientific --- magnetic flux does not affect evidence that this issue of the earth itself ----- that what you mean is microwave is issued from Mobile and cookers --- I hope that for yourself and read the more so as not to be ---- then more than 72 replies here from you and then!!!!!
  • Alexismex
    See............Decay of the third of the distance....Pi do not affect Health ...too small energy , but cellphone yes they affect the cells of your brain as we see all around us ...ZOMBI PEOPLE !!!
  • scs
    Attention-pi detectors seriously harm the health. Strongly electromagnetic field leads to cancer and heart disease.
  • mrmr16
    Hi Biogas
    you can use hcf4094 or CD4094
    and use jamper instead of D8 too
  • hadi-dindar
    this vldeo is test of dp3 http://minasoltani761.persiangig.com/14m.avi
  • Biogas
    Hi All!
    In the last mounts I was inactice (I see this topic was inactive too), but on Christmass holiday, I would like build the DP3!
    Than I would like know:
    I bought D Schottky D8 1 3Ah, it is good?
    And I don't fint this HCC4094BF what is good for it?
    Thank you!
    BR
    Biogas
  • farhad58
    file password
  • hadi-dindar
    hi jap
    i check my circuit and all the pins voltage are okey
    but i have 201hz freq in circuit .
    all the test is with guidance pdf.
    and my detector cant sense any metal.
  • jap
ID:	334027Hi turboaleks
    There are notes need an answer especially the image of No. 2 In part of LCD?
    best time
    j.
  • mrmr16
    Hi turboaleks
    whats information about your coil
  • jap
    Hi turboaleks
    -Nice PCB work.
    --Do you PCB works(Detection + mode Scope) ?
    best time
    j.
  • Nicolas
    Originally posted by turboaleks View Post
    @Biogas,
    i made pics of my DP3 and hope that some of your questions will be answered this way.
    The mini LCD form ebay hasn´t arrived yet, so i took another K0108 GLCD.
    The coil has 460uH and 3.6 Ohm.
    [ATTACH]22052[/ATTACH][ATTACH]22053[/ATTACH][ATTACH]22054[/ATTACH][ATTACH]22055[/ATTACH]
    Hi turboaleks
    Good Works
    my Congratulation
    Best time
    Nicolas
  • turboaleks
    @Biogas,
ID:	334006Click image for larger version
ID:	334007Click image for larger version
ID:	334008Click image for larger version
