Carl : "I don't recall any BFO detector from the 70's hitting coins at 8" "
My Bounty Hunter III with a 12 inch Jetco coil will do it with a quarter or larger in air, 6 to 7 on the ground. Anything smaller in diameter it rapidly drops to 3 or 4 inches on the ground. Seems there is a threshold right at the diameter of a quarter since distance abruptly falls off for smaller diameters no doubt due to the large coil. I do not know what it would do with the original 6" coil as mine was cracked. Looks like someone tried to take the coil apart not knowing it was a 6 inch diam. PCB ring where the turns were foil paths, the board embedded in a solid plastic ring. The moment they pried on the coil they cracked the PCB making the coil an open circuit. I traced it out by hand, if someone wishes to redo the schematic using a CAD program it would be nice if you posted it here. I will never know how well it operated using the original 6" coil but I am amazed how far this BFO detects with the 12" coil. I can hear my car several feet away (holding unit out horizontally) and looking for objects like cans it way out detects all my modern MD's for distance. Being my first BFO I am really annoyed with the constant retuning. Very sensitive to every change around the search coil. The ratio for the mechanical vernier is so high there is a wide dead spot at zero beat. Scale is 0-100, I set the trimmer inside the coil ( see pic) for zero beat at 50 on the scale just off the ground. I kind of like it since I think it would find the lid on a mason jar full of Gold Double Eagles that was deeper than all my newer models could. I believe in the 30's when they outlawed owning Gold a lot of people would have buried theirs. I know I would have buried mine so my theory is so would everyone alive back in those days. The handle design combined with the heavy coil make this model painful to use for long and the constant tuning is no fun either yet I think I will keep it for certain searches such as finding that metal lid buried deeper than most average finds would be.
