PROJECT ETI566
    Ops... lacked the transistor Q2 in the above list. Sorry
    Q2 - BC549.
      Receiver silkscreem and botton layerClick image for larger version
Name:	ETI 566 Receiver.jpg
        Transmitter, silkscreen and botton layerClick image for larger version
Name:	ETI 566 Transmitter.JPG
          PCB Receiver (150 mm x 55 mm ).
Name:	PCB ETI 566 Receiver.JPG
            PCB Transmitter ( 100 mm x 40 mm ).
Name:	PCB ETI 566 Transmitter.JPG
              Hi My friend is several meters deep and it will give you a list Qtatsh I should let the unit or the machine thanks
                Two box machines can go several meters deep on bigger targets. More real problem would be how to dig all those deep bigger targets detected.
                @Baterista: Thanks for clear PCB layout drawing.
                  Whether it is on your approved list of components and parts did not put it here, thank you thank you put it
                    Look at link in post #14 of this topic, I gave to nejdet, there you can find all parts and construction data of this project. Happy building.
                      If I understand the question well. Concerning to depth:
                      My field tests are done in the same place for all projects.
                      Pieces of iron, forming a block of 17 cubic centimeters, buried one meter deep.
                      And for this project has a clear and strong signal.
                      Has not yet been made a maximum depth test.
                      Need to dig, dig, dig ...
                        Thanks for the reply WM6
                          Thank you so much my dear friends it is a professional or a beginner Astadyd Do you think that is worth making because you commented on 5 or 6 meters
                            The coil circuit is made ​​about how to tweak it further explain thank you
                              I would say from 2 to 5 meters, an optimistic vision, but all depending on the mineralization of soil, size and how long the
                              object was buried.
                              As to whether it's worth building, it all depends on the ease of obtaining materials.
                              None detector is so good (professional), as we would like.
                                Thanks for your help in making the coils will get more help
