As for the phase detector mentioned above, it will have to deal with 4 quadrant stimuli, where same phase response is expected of signals in 1st and 3rd quadrants, and also 2nd and 4th. It goes as follows...
Say I have a silver coin, so it will have a response in a 2nd quadrant (counted from Tx phase), but also in 4th quadrant when a signal from coil comes in counter-phase.
I wish to have a continuously rising tone as a discrimination response from Fe to Ag.
So I have to obtain a continuously rising (or falling) phase detector response for the first 180° but also followed by a repeated same slope for the next 180°. A simple XOR gate as a phase detector is not providing this response, as it's ramp goes reverse in the 2nd 180° cycle. JK latch provides a single slope for the whole 360° span, but it can also work as a harmonic phase detector, and then it does precisely what I need: same ramp for both 180° sub-spans. A perfect 4 quadrant phase response. It will give the same target ID for every position of a target against a coil, and the best of all is that it is a linear response obtained without any analogue (or digital) calculation. All it needs is a hard limiter.
It must be emphasised that just because a signal from coil comes shifted for 180° it is still the same target that must be ID-ed as a same metal, and that's precisely what 4 quadrant detection is about.
What follows are the examples of 3 different phase detectors, and the most interesting is the response in red indicating a 2nd harmonic detection. Green is the XOR, and blue is non-harmonic JK latch.
