Whites 1000 PCB
  • Whites 1000 PCB
    I'm playing with the PCB of Whites 1000. I made the boards from a design published in some photocopies in this forum and drawings of Ivconic: Is it worth building it? Can anyone share something about the performance of this detector? Any help is welcome.
    regards,
    Fabian
Name:	Whites 1000 A.JPG
    I have the 2000 pi the next model up from 1000, which is a good detector,
    could you please attach the lay files thanks
      Hello 6666. It seems that no one else knows this MD around here ... Sure I can publish the lay files.
      Here I attach the files and photocopies of where I extracted the PCB's. According see in photocopies, is a very detailed project done with great care. I think I will start building to see if it works.
      White's 1000.rar
      Fabián
        Fabián
        Thanks for the files much appreciated.
        The 1000 has been around for a long time
        and work well, the main difference between the 1000 and 2/3000
        is the 1000 had a mechanical knocker that you put inside your wetsuit
        in the 2/3000 they went to tones in head phones.
        With my 2000 to tune it, you put the coil on the ground and turn
        the control to tune, wait a few seconds for it to settle
        then turn the control back to operate.
        The clock runs at 30Khz and is divided down to 3khz TX pulse via the 4017.
          latest
          http://www.geotech1.com/forums/showt...hite-s-PI-1000
            In the PI1000 the mechanical transducer was a 6 volt 4PDT relay. It was loud under water.
            These are hard to find now, but digikey still list them
            http://www.digikey.com/product-detai...B-6V-ND/649075
            It would be fun to replace the CD4017 fixed timing with an adjustable 8 pin pic chip.
              Like a 12f683 ?
                What is the complete loop؟
                  Loop
                  The instructions for winding the loop are on page 5 of the attached copies above.
                  WARNING: My boards are still not tested. I THINK they are fine, but I can not confirm now. Any comments about errors detected will be welcome.
                  Fabian
                    Bugs
                    Fabian
                    Some bugs fixed...
                      News
                      The news is that the boards are of the White's 2000, not 1000 (according to the diagram posted here by 6666) and is entirely consistent with the PCB´s of the copies and my PCB´s, which are not yet fully confirmed (yesterday I found two or three gross errors).
                      I Will keep you posted.
                      Fabian
                      PS: 6666, Have you got some pictures of your 2000 pcb¨s? Maybe with some photo´s we can confirm that.
                        Hi Fabian
                        Thanks for the info
                        sorry i dont have pictures of the pcb,
                        6666
                          The final PCBs
                          I think it's all good, I did not find errors. I found inconsistencies between drawings of PCBs and diagram are the values ​​of some resistors I guess I'll have to experiment when assemble. Now I am a bit complicated with time, but when I can, I will build and test.
                          Ah! I forgot: from now on, this thread should be called Whites 2000
                          Fabian
                            Thanks Fabian
                              There is a 1000 being tested on youtube with the relay knocker.
                              http://www.youtube.com/watch?v=q951fA2lMW8
