What will the answer be…?
I have 3 identical coins which are British Crowns made of cupro-nickel alloy. Diameter 38.5mm. thickness 3mm, and weight 28gm. Electrical conductivity is 5.5 as measured on a Sigma 2000 conductivity meter. That is 5.5% of the conductivity of pure annealed copper (100%). True TC is 45uS.
Using a small solenoid coil (35mm D) I put one coin on axis, spaced such that no saturation is taking place in the RX circuit. On a scope I now see a clean decay curve which merges with the noise round about 100uS. Plotting the curve on log linear scales between 20 and 100uS, I get a nice straight line, so it is a classic exponential decay.
I now place a second identical coin on top of the first with a thin insulating layer between, and the results plotted.
The last part of the experiment is to place the third coin on top of the other two, again with the insulating layer and a plot completed.
Comparing the results and also the scope traces, it wasn’t quite what I expected. What do you think I saw? Good question for the theoreticians, and for those with practical gear to do a test.
What’s the relevance? Cache hunting where considerable numbers of coins are together, but not necessarily in electrical contact due to oxidation.
Eric.
Eric.
. I expect the results will be rather different for other coins, particularly coins that are made of a more conductive metal e.g. silver or copper. Each coin in turn is attenuating the high frequency components of the TX waveform, giving less excitation to the next coin. Lower frequencies still get through to give the enhancement at late times. Star = 1 coin, Circle = 2 coin, Triangle = 3 coin.
