Originally posted by Davor
Multitone technologies make some sense on difficult ground, yet there is no mention of true benefits in the above mentioned pamphlet. Only various "possibilities" that are most obviously lost in diddle-doodle human interface.
A passage I referred to is absolutely meaningless in any technical sense. It may serve some marketing purpose, which obviously did not work on me, but otherwise there is nothing inside that will ever explain any facet of this technology. I'm not religiously tied to any metal detecting company, and so far I'm incapable of sucking to something like that.
I've seen videos of those monstrosities in action though.
All I can say is sit back and let the technology pass you by. I see you have not attempted to explain anything of the extract above. A clue for you.......
The first thing you should notice (check Golfnut's scope screen capture) is that this is not VLF and in no way can it be confused with VLF. It is Pulse Induction or be it unconventional Pulse Induction.
Harmonics???? If you agree that conventional PI is broadband, ie, transmits a wide range of frequencies, then it is obvious that square or rectangular continuous wave also has a wide range of frequencies. So comparing it to VLF is just wrong. It isn't VLF, it is unconventional PI.
I will leave it up to you to make up your own mind about this technology from here on in. If you don't believe anything I've said then I hope you are around in a year or two to see where it leads.
The best way to avoid this is to shunt this coil with resistor , about 1 Kohm .
