ART WORK ON HOME MADE DETECTOR
  • ART WORK ON HOME MADE DETECTOR
    whats the best way to do art work on a home build detector like numbers around knob controls and arrows to indicate volume...and general art work ????
    For some phases of design you can find tools as this:
    http://www.abacom-online.de/uk/html/frontdesigner.html
    others are left to your unlimited creativity.
      I use Visio. Also look at:
      FrontDesigner
      Front Panel Express
        If you are familiar with autocad, try using draftsight: http://www.3ds.com/products-services/draftsight
        It is free and available for windows, mac and linux.
          dunno if you mean actual design or construction, try either waterslide decals for laser or inkjet (famous auction site), or printable OHP film with a white paper backing stuck on with double sided tape
            Maybe these links will be of some help for ideas :
            http://jumperone.com/2013/01/how-to-...y-front-panel/
            http://aade.com/sexypnls.htm
              That's the same procedure I used for the Raptor front panel, except that the label was printed onto ordinary white office paper and then covered with sticky-backed plastic.
                I use a P-Touch labeler by Brother and clear label tape in 1/4", 3/8", and 1/2". It uses the TZ series of label tape cassettes and they come in a variety of widths and colors. It prints multiple lines of text depending on font size and tape width. It is self adhesive and very durable. I find the 6 and 9 point fonts to be most useful for labeling controls on my BITX 20A ham radio and on my CHANCE PI detector.
                Dan
                  i really need something that is suitable to go onto plastic film..i also need symbols to show tuning and increasing/decreasing volume....im not sure if a labeler will do what i want...im new to all of this making detectors and artwork...im the old school and take longer to learn things...i guess i will have to experiment with things.
                    In my experience symbols for straight/round scales are hard to find. Some of the software packages propsed here like frontdesigner offer them but they are not scalable. It is better to draw your own in some cad package.
                      You can also use LibreOffice Draw or OpenOffice Draw.
                      Other free alternatives to Visio are:
                      1. Dia -> http://dia-installer.de/download/index.html
                      2. LucidChart -> https://www.lucidchart.com/?utm_expi...-0wF1cnwtBnA.0
                      3. Pencil Project -> http://pencil.evolus.vn/Default.html (which is really simple to use, and runs on Windows, MAC and Linux)
                        What kind of graphic are you thinking of for tuning and volume up and down? The P-Touch has a wide and varied character set that is scalable. I'll try to find a site for that for you to see. The labels will stick to film or the substrate behind the film.
                          Are you talking about elongated curved triangles? its CAD you need to be using. Perhaps we could set up a graphics thread where people could request and post the type they wanted or had designed?
                            Corel Draw is all that is needed, only actual technology of producing prints may vary, i will post some examples if someone is interested.
                              Here is the specs page from the P-Touch labeler model PT-2030AD available at COSTCO for $37.99:
                              back to top Hardware Features
                              Model Type Desktop
                              Tape Family TZ / TZe
                              Tape Sizes‡ 3.5mm, 6mm, 9mm, 12mm, 18mm
                              Tape Length‡ 26.2'
                              Tape Technology Thermal Transfer
                              Tape Types‡ Standard Laminated, Flexible ID, Extra Strength Adhesive , Non-Laminated Iron-on Fabric, Acid Free
                              LCD Display 16-character x 2-line graphical
                              Maximum Print Resolution 180 dpi
                              Maximum Print Speed 10 mm / sec
                              Keyboard QWERTY
                              Cutter Manual
                              Batteries 6 AA (optional)
                              AC Adapter AD-24 (included)
                              back to top Software Features
                              Number of Fonts 4
                              Font Styles Helsinki, Brussels, Florida, and Calgary
                              Point Sizes 7 (Auto, 6, 9, 12, 18, 24, 36, 42 pt.)
                              Number of Styles 10
                              Built-in Symbols 253
                              Types of Styles Normal, Bold, Outline, Shadow, Solid, Italic, Italic Bold, Italic Outline, Italic Shadow, Italic Solid, Vertical
                              Max. Print Height 15.8 mm
                              Maximum Print Lines 5
                              Multi-Block Yes (up to 5 blocks)
                              Label Length Setting Auto / 30mm - 300mm
                              Auto Incrementation Yes (0-9)
                              Auto Numbering Yes (1-9)
                              Horizontal Alignment No
                              Vertical Printing Yes
                              Mirror Printing Yes
                              Text Framing/Fill Pattern 16 Frames ⁄ 1 Fill Pattern
                              Multi-copy Print Up to 9 copies
                              Memory Yes (up to 9 labels)
                              Date/Time Stamp No
                              Built-in Designs/Templates 55 Label Collection designs
                              Auto Formats 31 (including Block Layouts)
                              Barcoding Yes
                              Barcodes (Stand-alone mode) CODE39, CODE128, EAN-8, EAN-13, GS1-128 (UCC/EAN-12, UPC-A, UPC-E, I-2/5 (ITF), CODABAR
                              NOTE: I have no business interest in COSTCO, Brother, or it's products.
                              The products have just worked very well for me in labeling my projects.
                              Dan
