Hi folks.
I built a Surf 1.2 a while ago for a friend, it was working well but I thought I could get more performance from it.
It was detecting a slim white gold wedding band at 8 1/2" and a £1 coin at 13" in air indoors, which I thought was very respectable.
Using a coil: Ø 300mm/12" L= 321.1 uH C= 63.43 uF R= 5.629Ω made from 22 swg enamel copper wire bundle, which was tied then wrapped with a thin coat of insulation tape, then spiral wrap, & finally notched aluminium foil leaving a gap of approx 6-8mm.
I was attempting to tune the damping resistor value using a 1K2Ω in parallel with a 4.7kΩ variable + 250Ω
For some reason the detector has stopped responding to targets and just sounds like its nulling / ringing all the time.
I'm afraid I've toasted or damaged a component but I don't know which one or how to tie down the problem.
I've tried several coils that have worked with the circuit. I've tried varying pulse delays from 8uS to 60uS but nothing seems to work.
The offset is bang on 0v
I've got a DMM & a PC based oscilloscope (I'm learning to use it though).
I also have a Megger B131 LCR meter at my disposal.
Below is a screen shot of the scope without a coil connected to the board:
[IMG]
[/IMG]
Below again is a screen shot of the scope with the afore mentioned coil connected:
[IMG]
[/IMG]
As mentioned before I'm very much beginner when it comes to using a scope, the same is true with electronics as a whole.
Any help would be very much appreciated as I only have a very basic grasp of the workings of a Pi machine.
[IMG]
[/IMG]Below again is a screen shot of the scope with the afore mentioned coil connected:
[IMG]
[/IMG]As mentioned before I'm very much beginner when it comes to using a scope, the same is true with electronics as a whole.
