(I was checking some coils that I have and saw something I didn't understand. Why a big difference in the decay time? Including a plot. Channel 1 is the coil volts, channel 2 is (U1 output mono coil amplifier reply#7), Rd is R5, Mhz is decay freq. with Rd disconnected. No target, no shield, 24awg is solid.)
(Making a Fast Pulse Induction Mono Coil) says to use stranded for AWG 22 to 26. I don't have any 24 gage stranded. I tried some 28 awg teflon coated stranded to compare with the 28 gage magnet wire. A small difference. Should the coil response with 24 gage stranded look similar to the 28 gage magnet wire if coil specs are similar except for resistance?
to test coils and adjust dumping to real conditions instead to do it in air.
