LC meter
  • LC meter
    hello, I'm starting to build an IDX Pro and I wanted to build a induttometro to accurately measure the inductance of the coils;
    On the internet I found many plans, but I seem to have understood that the resonant frequency of the coil must be greater than the frequency with which it will be analyzed, as a result many projects are not "good",
    you could recommend a good lc meter to measure the inductance of the coil metal detector?
    ps I know to program the pic, I do not have an oscilloscope
    Yes, if the measurement kit uses an interrogation frequency that is close to the self resonant frequency of your coil - you can get odd results.
    If the measurement frequency is adjustable, select the one closest to the operating frequency for your coil.
    I have used digital Hewlett Packard L bridge for a TGSL coil for 14kHz.
    With the kit set at 1kHz - no problem good reading
    With the kit set at 10kHz no problem same, good reading
    With kit on 100kHz the readings were wildly different and going positive and negative! and varying.
    I used other measurment kit and could see my coil was resonant at about 98kHz
      you could tell me the link of a lc meter with pic and related code written in C so as to use a 16F688 that I have at home?
ID:	341343Click image for larger version
ID:	341344Click image for larger version
ID:	341345Click image for larger version
ID:	341346Click image for larger version
ID:	341347l.c. meter.zipjust finished a lc meter that uses a pic16f628. Got the schematic and hex code from https://sites.google.com/site/vk3bhr/home/index2-html and expalins how to calibrate the meter.
        It is simple to make and is pretty accurate & easy to use.
        I have attached photos of my unit and a zip file with pcb artwork, pcb layout, schematic and code.
        Last edited by Finderskeepers; 07-25-2014, 04:11 AM. Reason: forgot to attach photos
          LC meters with a simple microprocessor are great for Metal Detector projects. There are also several LC meters on the internet which use the Arduino platform, see Google. Very easy to build!
