Thanks Kev! I appears that I have some work to do.
I will swap the coil leads and see what effect that has. I am troubled by the fact that you are saying that the coil is saturating. I need to make sure that there is NOTHING close to it. The "delay" pot seems to be P2, so I will adjust that to increase the time as you suggested. I will also replace the damping resistor with higher values until I get a waveform closer to the one that you provided.
Thanks for all of your help! On to the bench!
