DSP in commercial prospecting and treasure hunting metal detectors ... and GPZ 7000 speculation
  • #46
    Actually, that's not correct. To increase the resolution you need to use decimation in conjunction with over-sampling. Integration alone will only help to increase the signal-to-noise ratio. The downside is the extra time required to perform the oversampling and decimation process.
    Thanks for the correction. That is not what I understood from my research. (see the atmel explanation below)
    In the pic24 the oversampling takes no extra time. It may also have a decimation feature as well, if I remember right.
    It is a *very* impressive ADC system.
    If it only had more ram, I would have picked it for everything. As it was, it would have made a good front end for the GG project, but there would still have to have been a way to get the data
    transferred to a more capable processor for the processing.
    So could you please explain to me how one would use decimation along with 10x oversampling to increase the resolution? I understand that decimation is used to reduce the data rate, i.e. throw away every few samples, but how would that improve the resolution?
    The PIC24 also has a 16 bit sigma-delta but it only is a 62,500 samples per second ADC and would not be completely adequate to fully sample much over a 6592 hz signal with any kind of resolution. Sure it could get the nyquist criteria, but that would be about the same sample rate as the arduino.
    here is what atmel has to say
    Oversampling is a
    process of sampling the analog input signal at a sampling rate significantly higher than the Nyquist
    sampling rate. The main advantages of oversampling are:
    1.It avoids the aliasing problem, since the sampling rate is higher compared to the Nyquist samplingrate.
    2.It provides a way of increasing the resolution of the ADC. For example, to implement a 14bit converter, it is
    enough to have a 10 bit converter which can run at 256 times the target sampling rate. Averaging a group of
    256 consecutive 10bit samples adds four bits to the resolution of the average, producing a single sample with
    14bit resolution.
    3.The number of samples required to get additional n bits is = 2n^2
    4.It improves the SNR of the ADC
    • #47
      If you oversample the RX signal, and then divide the accumulated results by the number of samples, you will still have the same resolution as if you took only one sample. The only difference is a reduction in noise.
      To increase the resolution of an ADC by one bit, you need to oversample by 4x. Somewhat counter-intuitively, the oversampling and decimation process requires a small amount of noise to be present in the signal. In other words, the signal needs to vary by at least half of the least significant bit, and in practice 1 to 2 LSBs are better. If the signal is essentially noiseless (less variation than 0.5 LSB) you will need to artificially add noise. This is referred to as "dithering" - something my wife is very good at. By the way, decimation is often called interpolation.
      The process of decimation is fairly difficult to explain in a few words, but luckily is simple to implement. Basically, instead of adding the extra samples m and then dividing by m, you right-shift the added samples by n, which represents the extra bits of resolution required.
      If you read the attached App Note, then things will become a lot clearer.
      • #48
        This thing uses 1024 boxcar filtering of 4 phases and thus it increases resolution for additional 5 bits. Simultaneously you have a very neat LPF with very favourable impulse and phase response for a decent detector. I'm not overwhelmed by joy, but this can work.
        • #49
          STM32 the is the way to go. STM32F3 or F4 can sample 12 bits at 20nS
          You can setup a nice ADC/DMA stright to your buffer then process it. It is absolutely amazing what that chip can do. Plenty of memory, 72MHz, DAC for sound or to drive coil, etc....
          Here is a sample plot from the simple PI detector. Signal sampled after the first and only opamp (used to shift and expand signal to the ACD range)
          plots of "base line - no target", "steel" and "gold".
          After you have the profile then slow/fast integrators are done in software to detect target.
          I fried my STM32F3 (12V charged cap plugged into 3.3V ooops); Just got STM32F4 nucleo but did not have time to play yet, the spec are spectacular .
          • #50
            Originally posted by scrungy_doolittle View Post
            ... there are two more of these He says he is removing the 3rd harmonic and dividing by 200. What the heck is this doing
            This way of addition of 3 consecutive samples actually removes the 3rd harmonic, and with factors sqrt(0.5) also the 5th as the components of the 3rd and 5th contained in them get mutually subtracted. Higher harmonics are far more volatile with changing ground proximity, so this will give more quiet rig. Even harmonics are removed due to the balanced sampling.
            I have no idea why dividing by 200, and it must have something to do with arduino atan2 function that returns arc tangent of y/x. Applying ideal atan2 function would yield same result with and without divide by 200. As I'm not familiar with arduino math, I have no idea what might be the motive there. Most probably atan2 is based on some lookup table and precision may vary.
            What would I do different?
            First off, I'd avoid micro in the first place, despite the tempting FIR boxcar filtering. Lets pretend I regained my liking for the micros.
            First there are a few details that are missing here, namely ground balance. Without it this is merely a nice pinpointer. To add a ground balance, one should play with phases in a way that linear combination of the orthogonal phases (bin0⊥bin2 and bin1⊥bin3) produce zero at ground phase. Simple really, as the routine to establish phase is already implemented. In the end the amplitude (all metal, no ground) is absolute value of the ground balance vector, instead of the sum of squares, as implemented now.
            The fun part with this rig is that it is fully static, with simple "calib" function to remove offset. It would be much simpler if there is a simple boxcar highpass added as well, but it would take many more samples to average than just 1024. If there is enough memory to do 1 full second or more, it would be interesting to see perfect FIR slow motion detector with no ringing. Switch on and go - that simple.
            So my approach would be to add FIR boxcar high pass in duration of, say 4 seconds, and a button to turn on GB calibration in place of the "calib" function used now. THAT would be something else.
            • #51
              Having looked at the code some more, I think I now understand how this is supposed to work.
              Firstly, an array of 4 bins are declared, which are used to accumulate the ADC readings. One cycle is split into 4 equal parts (90 degree quadrants) and are referred to as "phases" (0 to 3). The ADC capture is performed in the ISR (interrupt service routine). Two samples are taken per phase, making a total of 8 readings per cycle. After 1024 sets of readings have occurred, the contents of the bins are deposited into an "averages" array.
              Then 4 different "bins" are declared, and the mysterious addition and subtraction process takes place. Initially I assumed that each of the 2 samples per phase were positioned around the zero-crossings and the positive and negative peaks, as this would make most sense. In that case, we would have the following:
              phase0 = positive-going zero-crossing -> bins[0] -> averages[0] -> bin0
              phase1 = positive peak -> bins[1] -> averages[1] -> bin1
              phase2 = negative-going zero-crossing -> bins[2] -> averages[2] -> bin2
              phase3 = negative peak -> bins[3] -> averages[3] -> bin3
              With the ADC samples positioned around the zero-crossing and the peaks, we can examine the following code snippet:
              double bin0 = (averages[0] + halfRoot2 * (averages[1] - averages[3]))/f;
              where: halfRoot2 = 0.7071 and f = 200.0
              In this instance, the calculation becomes:
              bin0 = ((postive-peak - negative-peak) * 0.7071) + positive-going-zero-crossing
              f appears to be an empirically defined fudge factor.
              Assuming the peaks cancel (not sure why he's bothering to find the RMS value at this stage), bin0 will mainly contain the reading at the positive-going zero-crossing. Likewise, you can analyze the other three phases in the same way, and get the following:
              bin0 = positive-going zero-crossing
              bin1 = positive peak
              bin2 = negative-going zero-crossing
              bin3 = negative peak
              Next he calculates the absolute amplitude at the zero-crossings:
              double amp1 = sqrt((bin0 * bin0) + (bin2 * bin2));
              And the absolute amplitude at the peaks:
              double amp2 = sqrt((bin1 * bin1) + (bin3 * bin3));
              So far so good.
              At this point he has all the ingredients to achieve both ground balance and discrimination, together with VDI.
              But then things start to go a bit awry.
              Instead of calculating the inverse tangent of bin1/bin 0 and the same for bin3/bin2. In other words, calculating the in-phase and quadrature components of the RX signal, he calculates the inverse tangent of bin0/bin2 and likewise bin1/bin3, which really doesn't make any sense at all.
              IMHO this shows a basic lack of understanding of how a VLF detector works. In fact, he states:" So we'll say that anything with a phase-shift below -20 deg is non-ferrous". Which indicates that the detector is only designed to give a ferrous/non-ferrous indication.
              As Davor correctly said: "..... there are a few details that are missing here, namely ground balance".
              Which is a shame, because everything is there to make it happen.
              In conclusion, I suspect my initial assumption (that the samples are being taken around the zero-crossings and peaks) is incorrect, and the samples are actually being taken in the middle of each quadrant (phase). In this case, any anomalies in the signal (due to harmonic contamination) will be reduced, but the ability to ground balance and discriminate with VDI will be lost.
              According to some comments made concerning this project, it is long defunct, and apparently never made it off the bench.
              • #52
                There is a potential to this, but ...
                BTW, the samples are 45° apart, so bin 0 and bin 2 are in quadrature, and also bin 1 and bin 3 are in quadrature, but 45° further, and atan2 returns the vector angle between them.
                • #53
                  ..... the samples are 45° apart, so bin 0 and bin 2 are in quadrature, and also bin 1 and bin 3 are in quadrature, but at angle, and atan2 returns the vector angle between them.
                  The samples are 45° apart, but the quadrants are separated by 90°, which puts them in quadrature. Bins 0 and 2 are actually 180° apart (same for 1 and 3). Remember, there are two samples per quadrant.
                  Basically, the calculations are a mess.
                  • #54
                    Errr... no. If averages[0] is taken at 0° (and also at 180°but in counterphase) averages[1] at 45° and so forth, the math is correct. However, it simply can't improve faith of this thing. There are a few details I'm stealing though
                    In a way there is a similar path to this that could lead to a proper amateur multifrequency rig that could perform well on salt, mineralised, and even viscous grounds. With obscenely simple code and no pompous math. However, 10 bits, and in fact even 12 bits ADC is downright silly.
                    This is why:
                    Say you aim for not-too-ambitious 4nV/sqrt(Hz) performance, and your target bandwidth is 25Hz. It gives 4nV x sqrt(25) = 20nV of input referenced noise. Say we put a 100x preamp as well, and we get to 2uV amplified noise level. With such amplification and a good coil, we get, say, 200mV worst case air signal, and S/N ratio of 100000. Throw in a sign bit for negative values, and you get over 17bit resolution. 10bit ADC is simply not in that not-too-ambitious league.
                    • #55
                      Here is Mr Crocker's reply to my email.
                      This is why:
                      Here is Mr. Crockers reply to my questions.
                      Dealing with the arduino metal detector, I'm trying to understand
                      certain parts of the code, what you are doing and most importantly
                      why. I'm a bit math challenged, but I also
                      am an embedded firmware engineer with 30+ years experience.
                      So please make it really clear...
                      first question is in the ISR . It looks like you are sampling 4
                      times per half cycle. BUT on the negative half cycle, you are
                      *subtracting* it from the buffers.
                      The ADC returns a number from 0-256. Where is it biased? I.e. is the
                      adc seeing the value as signed?
                      The hardware (see schematic on github) uses a single rail op amp to
                      amplify the signal from the receive coil. The output of the op amp is
                      biased to approximately half the voltage on the 3.3V rail, which is also
                      used as the ADC voltage reference. So at the zero crossing point, the
                      ADC reading is approximately half of the 255 maximum ADC reading.
                      What value does it return for the zero crossing point (degree 0 and
                      180) of the sine wave.
                      If you sample at say 45 degrees and 135 degrees, and you get say a +70
                      for the first one and a -70 for the second, then subtracting the
                      negative 2nd one from the bucket is the same as
                      adding it in. Taking the abs and adding it would have been a bit
                      clearer if that is what is happening.
                      Taking the abs and adding it would not work. What I have implemented is
                      a phase sensitive detector in software. Are you familiar with phase
                      sensitive detection? The idea is to measure a signal of the same
                      frequency as the reference oscillator, and be insensitive to signals at
                      other frequencies (including 50/60Hz mains).
                      If however you would get a 0 for the negative peak of the sine wave,
                      than all numbers will be positive and you would not be adding things up.
                      So what is happening here....
                      if (ctr < 4)
                      *p += (val);
                      if (*p > 15000) *p = 15000;
                      else
                      *p -= val;
                      if (*p < -15000) *p = -15000;
                      Suppose the ADC gives a reading of 100 with no signal. The additions and
                      subtractions will cancel out, so after a whole number of cycles, all the
                      bins will be zero. It doesn't matter whether the no-signal reading is
                      100 or some other value around the middle of the ADC range, as long as
                      it doesn't change too often. Now suppose there is a signal, giving a
                      reading is 103 on the positive peak of the signal, and 97 on the
                      negative peak. If one of the 4 samples in the first half cycle catches
                      the positive peak, and 4 samples later we catch the negative peak, then
                      for every cycle the corresponding bin will increase by 6.
                      I'm limiting the value in each bin to +/- 15000 to avoid arithmetic
                      overflow in the subsequent calculations when the signal is strong.
                      The next question involves the following:
                      // Massage the results to eliminate sensitivity to the 3rd harmonic,
                      and divide by 200
                      double bin1 = (averages[1] + halfRoot2 * (averages[0] + averages[2]))/f;
                      double bin2 = (averages[2] + halfRoot2 * (averages[1] + averages[3]))/f;
                      double bin3 = (averages[3] + halfRoot2 * (averages[2] - averages[0]))/f;
                      What is going on here?
                      Why the addition of .707 to the raw ADC reading?
                      Why the division by 200? What is that accomplishing?
                      Where is the division by 1024 samples to actually compute the averages.
                      How does this cancel the 3rd harmonic?
                      and why are some of these additions and some subtractions.
                      You really need to understand Fourier analysis to appreciate how this
                      cancels the third harmonic. I can't remember why I divided by 200, I
                      think it was just to make the displayed numbers more manageable when I
                      was debugging and writing the 4 bin values to the console. Dividing by
                      256 might be more efficient, depending on how the floating point maths
                      library is written. Now that the debugging code has been removed, it
                      would be simpler to divide the final amplitude by 200 instead, or to
                      just accept that the final amplitude covers a larger range.
                      At the start of this calculation, the 4 averages give the amplitude of
                      the received signal measured at 4 different reference phases, 45 degrees
                      apart. At the end, the 4 bins also give the amplitude of the received
                      signal measured at 4 different reference phases 45 degrees apart, but
                      the 3rd harmonic component of the signal has been cancelled, and the
                      result has been converted to floating point and scaled down to a more
                      reasonable range (about -100 to 100 I think).
                      There is no need to divide by 1024 because we are not interested in the
                      absolute value of the signal, just its relative value. The code
                      calculates a scaled average rather than a true average.
                      This is the biggest question. I want to understand *exactly* what is
                      going on and why.
                      I understand the sqrt(bin0^2+bin2^) but why bin 0 and 2 and 1 and 3?
                      I said earlier that the software was implementing a phase sensitive
                      detector. More precisely, it is implementing two quadrature phase
                      sensitive detectors with reference signals 45 degrees apart. Each
                      quadrature detector itself comprises two phase sensitive detectors with
                      reference signals 90 degrees apart. The first quadrature detector
                      produces results in bins 0 and 2, the second produces results in bins 1
                      and 3.
                      Consider just one quadrature detector. We know the component of the
                      received signal at the reference phase, and the component at 90 degrees
                      to that phase. Assuming the signal is sinusoidal, to find the amplitude
                      of the actual signal, we need the square root of the sum of the squares
                      of the two components.
                      At this point, we could take the output of just one of the quadrature
                      detectors, and calculate the amplitude and phase from it. But has we
                      have 2 detectors (which is a consequence of sampling 8 times per cycle
                      instead of just 4, which is what allowed us to cancel the third
                      harmonic), it makes sense to use both outputs. So I calculate the signal
                      amplitude from both phase sensitive detectors, and average them.
                      I also don't understand how the phase adjustment is working.
                      The next question concerns:
                      double phase1 = atan2(bin0, bin2) * radiansToDegrees + 45.0;
                      double phase2 = atan2(bin1, bin3) * radiansToDegrees;
                      I know that the arctan will give the phase angle of a vector, but
                      again why bin 0 and 2 and why the addition of +45 to the resulting
                      degree measurement.
                      Bin 0 and 2 because they give the signal amplitudes from samples taken
                      90 degrees apart. Likewise bins 1 and 3 give the signal amplitudes from
                      samples taken 90 degrees apart, however those samples are taken 45
                      degrees later than bins 0 and 2. Hence the +45 so that both phase
                      results are referenced to the same point in the cycle.
                      Is this measurement essentially the same as the VDI that takes the X
                      and Y voltage components, and computes the phase angle? (there is an
                      arduino VDI posted on the Geotech forums).
                      Sorry, I don't recognise the acronym VDI.
                      What I want to do is to modify this code so it works with 6.592 khz
                      whites detector coils.
                      I have found a T1 divisor of 243 and a sample divisor of 10 will let
                      me use a clock frequency that gives me 6.592 khz to generate the
                      clock, but
                      That means sampling not at 8 times, but at 10, so rather than 45
                      degrees it would be 36 degrees. I KNOW from many hours studying
                      whites schematics, that 90 degree sample is important.
                      It would not work having 10 samples per cycle. I guess you could use 12
                      samples (3 quadrature detectors instead of 2), but without doing the
                      maths I don't now whether you would be able to cancel the third
                      harmonic. Your detector coils won't mind a slightly different frequency,
                      so I suggest you use a slightly lower frequency that gives you a
                      convenient divisor.
                      I am also working on using an ARM (ST32F411 nucleo board) for a IB and
                      PI metal detector. In that case, we have a 1 usec sample rate, and I
                      can digitize the entire waveform using
                      the DMA feature. Then I can integrate between various samples, but I
                      need to understand what you are doing here, because that is directly
                      applicable.
                      Additionally, I don't see any filters happening here to remove high
                      frequency and low frequency components, such as 60 cycle hum etc.
                      The phase sensitive detection makes the system insensitive to
                      frequencies other than the operating frequency and some of its
                      harmonics. The amplifier incorporates simple high- and low-pass
                      filtering. All that is needed is enough to prevent strong signals such
                      as 50/60Hz mains and long wave radio overloading the amplifier.
                      • #56
                        So far so good.
                        One thing he pointed out is the additions and subtractions will result in the bins being 0 when no signal is present.
                        So assume that no signal is 100. a signal comes in with 103 and 97. This will result in the bins having 6's in them.
                        The adc is biased to approx 1.6 v. I have posted Mr. Crockers reply later on, but here is his explaination of the bins.
                        going on and why.
                        and 3.
                        degree measurement.
                        • #57
                          It is actually quite easy. Suppose you have a vector at any arbitrary angle, and you have its Cartesian values x and y. "atan2" returns the angle in radians of such vector with given x and y values. In case your metal detector samples two channels at precisely 90° apart, the signal values in those channels, or bins if you like, are those x and y values. In analogue VLF rigs you have a disadvantage of not having a real atan2 function at hand, so you perform tricks to discriminate, but in a micro, or VDI, you perform atan2.
                          Bin 0 and 2 are at 90° degrees apart and there you have it.
                          VDI is some fancy acronym for a gizmo that tells you a degree of a target at hand. Actually atan2 function and a display, nothing more.
                          Mr. Crocker's device lacks ground balance, and it is not merely a 90 degree thing. People make mistake when they confuse all metal reference with ground balance. Just ask if you want to know more about these.
                          • #58
                            OK ... so he's actually taking 4 samples for the positive half-cycle, and then repeating the process for the negative half-cycle. Not as I said previously - taking 8 samples per cycle, with 2 samples per quadrant. Which is completely different. Of course, in that case it's possible to accurately extract the amplitude and phase from the RX waveform. But ... there is still no mechanism for ground balancing.
                            • #59
                              I thought that ground balance was simply shifting the sample point one the received curve relative to the transmitted curve. In which case you would need a good deal more than 8 values. I would think you would need at least 360 samples, so you could adjust the ground balance to a precise degree, or am I just smoking something
                              • #60
                                Dump on me please. I'm all ears to know more about this, as I want to create a open source metal detector based on a micro. While I am a bit math challenged, I have over 30 years experience in the embedded world.. I know about VDI, but Mr Crocker did not know the acronym. So lets talk about how to fit ground balance into code similar to this. And, I would ask, that if anyone creates any code based on these ideas that they post it, either on github or other open source site so all may see it. I take my hat off to Mr. Crocker for having done so.
