Try Walmart. For $3 you can buy a can of "Great Stuff". I believe it to be a polyurathane type expanding foam. Dries fast, gets very hard, is waterproof, non-conductive, and extremely light. Just have to figure out how much to use as it expands pretty good.
We dont have a walmart in the UK. Our epoxy is quite expensive. Hi Sinclairuser; I have found some slow cure epoxy, it is clear but Im not too bothered about that. Have a look;
We dont have a walmart in the UK. Our epoxy is quite expensive. Hi Sinclairuser; I have found some slow cure epoxy, it is clear but Im not too bothered about that. Have a look; http://www.resin-supplies-shop.com/e...roducts/cer750
that looks ok, it depends how hot it gets as it cures, if you are unsure give them a ring.
If your making a PI coil, any PU resin should be ok
I got mine form here http://www.maragon.co.uk/arts-and-crafts.html#Print1
I used the casting resin, mixed with about 40% fillite powder to lighten it - certainly didn't melt or warp my coil shells (from Don)
I even used some colour paste although if using a scuff cover thats not needed
yes the poly resin i used took about that long, which was ok since it was an ib pi coil and allowed me to tweak the balance as it set.
i mentioned the heat issue since from experience i have found fast cure resins can get quite hot when curing.
i have recently made a small ib dd coil, and used wonder gel(mentioned in another thread) it seems ok.
