Funny thing I was going to post about that in my last reply.
That's something I thought about a while back for my PI. I would just have to redo the PCB into a long version.
Had it all figured out and it would mount under the armrest. For the land unit I was going to use aluminum for a shield.
It would have had to be at least 12" long to fit everything and was going to be somewhat a pain to mount all the toggle switches and pots.
End caps would have to be machined with an o-ring groove for water units. I already figured out how to keep the end plates in place and snug..
If using plastic for a water unit, make sure it has some UV protection. You would want polycarbonate tubing. What held me back was the cost if you wanted 1/4" thickness and 2 1/2" + outside dia. size.
You can use some PVC tubing with end cap fittings like they have for water filters. Take a file and file in the flats for the pots. Another idea was buying a water filter housing and cover. Couldn't find the right size
at a reasonable cost. Now if you know someone in the water filter business, they may have some used stuff on hand cheap.
