i want to use the LT 1028 in my surf pi but i cannot get the output to zero using the offset preset...i can only get it to about 0.6v...anyone throw any light on this please ???
LT 1028 OP AMP QUESTION
In LT1028 sheet it says:
"The input offset voltage of the LT1028/LT1128 and its drift
with temperature, are permanently trimmed at wafer test-
ing to a low level. However, if further adjustment of V OS is
necessary, the use of a 1k nulling potentiometer will not
degrade drift with temperature."
Linear Technologies gives the inner structure of LT1028 in http://cds.linear.com/docs/en/datasheet/1028fc.pdfLast edited by Davor; 10-21-2015, 09:23 AM. Reason: Found a proper pdf with inner schematic of LT1028
ive now zero volts on the output of the LT 1028....i just had to change a resistor value...i cannot now see any difference between the LT 1028 and the NE 5534...think i will stick with the NE 5534 op amp in the future !! im enjoying experimenting with the surf pi and trying to make small improvements to try and get that extra depth !! where i live the gold rings are very deep now and not even the dual fields are deep enough so im trying hard to get that bit extra depth which hopefully will give me that little bit advantage
how about to choice the opamp not per the noise but per Slew Rate?
your 'very good small noised' LT1028 has 13V/us slew rate, while for example AD845 has 100V/us. LT1028 is best for VLF
design, but for pulse induction you have still to think what is 'good'...
