Henrikras wrote:
Sorry but I haven't readed this post before.
Thx for the yt clip!
Your opinion about the Racer and his sensitivity is correct but I found out that
the DeepHunter with 33cm standard coil motion-circuit is still more sensitive
and around 15-20% better for e-smog regions and high-mineralized soil.
Btw. alot persons here also have not honored the Makro Racer!
I don't know what is their problem, many for shure are addicted to the oldschool P.I. technology
or they are not that willingly enough to adjust theirselves for the more complex new detectors.
I don't care, the Racer is THEEE detector so far: Search alot very easy and find alot very easy !!!
Incl. listening to the best music in loud HiFi Quality while hunting - that rocks!
Shure iron... - the problem is that every detector will "start" with iron an end with iron.
Concerning critical and farest depth for fainting targets - no matter what metal they are,
at the limit region everything first shows up as iron!
But the Jeohunter and DeepHunter is able to find "below iron".
Per instance the metalurgic remainings of black-smiths 2000 years ago.
Consistence like meteorites. Also all kind of mineralized stones.
There is no 100% iron-discrimination because the deeper the find is and the more
mineralic is the soil the more the find will say "I am made of iron".
I don't know the DRS ground Exper PRO but it looks like a P.I. machine
with its 1m coil and with P.I. you will never get "perfect discrimination"
because you can get hardly disc. at all.
And those 1m coils work nice and deep with steady in air tests
but you must consider to walk around with this stuff, too.
Why don't you save your money for the moment and use just the Racer with the 40cm coil
to get an overview over that viking-site ?? Check out an 500x500 square-meter area
instead of a 50x50 one.
This way first you can discriminate by size! Which is in the beginning much better
than by metal. With a little bit of luck you will detect a hoard where the coins are
very close together inside a pot or long time ago rotten leather-bag!
Believe me, if you don't go to all available places nearby and hunt over them at least once
you'll never know what you may miss there!
If you have found already a place with coins the whole region could be full of valuable stuff!
But if you are now addicted to the viking coins... - then I recommed that you clear the forest
first until you can see the tree
- that means you will have to dig also some old iron stuff
so you can be shure that you also found the most deep silver or gold coins! Good Luck!
Thanks Funfinder...
Ps. I Just got the Makro Racer a month ago... With all 3 coils. Yes this Detector is AWESOME, allso among iron.
Made one simple test with some silver coins and last with a 0.55 silver coin (just a little smaller size and weight as my viking coin from the hoard) and a rusty iron nail, and did a Deus vs AT Gold vs the Racer... http://youtu.be/49zl0mhVsHY
After the test (see it at utube), I found out that the Racer with the Stock coil is much more powerfull and Thats Maybee why only this Detector could get a signal from the coin, close up a iron nail. Because the coin was at the border to the Deus and the AT Gold.
(Could be the reason that the Deus and the ATG gave a Weak signal without the nail close test)
- that means you will have to dig also some old iron stuffso you can be shure that you also found the most deep silver or gold coins! Good Luck!
