so why first is VLF, but second is PI? monocoil in FI? - a PI can be also with RX coil. not argument.
Mostly for the kind of processing that follows. All PIs have no voltage source connected to the coil after the Tx excitation, while all VLFs do.
The physics work the same for PI and VLF.
I liked it back when Strecker was the Examiner. He knew his stuff, and even if you thought you were in the clear, he'd usually shoot ya down. Blew about 90% of what I claimed into the weeds. No hard feelings, that was his job, and in the process I learned a lot.
I work as a patent examiner myself. Shooting down is the only fun of the job.
Well, it is also PI because it demodulates the resistive component in the time domain during the periods of zero reactive voltage across the transmitter coil. New technique, some of us have known for a long time that it was theoretically possible, but to achieve zero reactive voltage across the transmitter coil close enough to perfect to make it worth the trouble, while current is flowing through the transmitter coil, is a tough engineering challenge and that's why it took so long for a company to actually achieve a marketable product with it.
without o-scope pics and schematics all your texts are only abstract discourse. chukcha ne pisatel', chukcha - chitatel', eah? =)
look at fisher impulse driver and CZ-5 driver and find difference. while FIRST IS PI, SECOND IS VLF. yup, fisher impulse has voltage source connected to the coil, via capacitor. so you are ON MY SIDE NOW, Davor?
Davor, BBS works in same manner like Fisher Impulse, excluding 'bbs'.
BBS - full bridge driver, un-resonance coil
Fisher impulse - half bridge driver, un-resonance coil
FISHER IMPULSE IS NOT PULSE INDUCTION detector, but some people in MD industry actively PR some detectors as
PI. ADVERTIZING for dummy users.
The only thing that makes the Impulse transmitter different from conventional PI in terms of waveform, is that the flyback is of longer duration due to being clamped at a lower voltage. The receiver is off while current is flowing in the transmitter coil. It is not in any sense whatsoever a VLF.
And, you're mistaken about the resonance issue: there are patents on resonant transmitter PI's although to my knowledge none are marketed to the general public.
The distinctive feature of PI is intervals of zero reactive voltage across the transmitter coil (usually because there is no current flowing, the GPZ7000 is the exception), during which the receiver detects resistive phase voltages induced in the receiver coil (which may be the same coil, or may be IB or some other configuration). In the schematics forum of this website you can find many, many examples of both PI's and non-PI's, and US patents are available for free online (and I think also on this website?)
I have built PI's which also demodulated signals while there was current of changing amplitude flowing in the transmitter coil, which as a practical matter requires induction balance. I believe this was disclosed in my CZ/Impulse patent. I'm close to certain that the GPZ7000 also does this. This is a time domain VLF method. So a given machine can be both a VLF and a PI.
No. Actually you decided some time ago that my side is different from yours, but that's beside the point.
Ever heard of tri-state logic? It is achieved with the same half bridge you often mention, but with slightly different drive. Impulse uses it. There is no voltage source connected to the coil while receiving.
CZ transmits a pure square wave, plain and simple. A rail voltage is constantly there, either + or -, but always there. When polarity changes, the current forces itself through the coil back to the battery, and that's the reason it is efficient. But the real mojo is in Rx. It processes signal in frequency domain. It might as well process it in time domain, or combined. You have a lemon, and a few ways to squeeze it.
By the way , the good method to distinguish PI machine from VLF is to observe a method of RX signal processing .... if our receiver analyzes only a fundamental frequency (f) of the TX pulse sequence ( or maybe 2 or 3 frequencies ) - this is a kind of VLF . But if we use simultaneously all the harmonic series of the coil current ( f , 2f , 3f , 4f , etc ) - we have a PI device .
The Minelab circuit and waveforms and patents have been around for more than 20 years. The "BBS" etc. technology is not PI. It is sequential multifrequency.
I'm glad you've said that, as several people seem to be under the impression that Minelab's BBS machines are PIs with discrimination. This erroneous idea seems to be prompted by some misleading marketing. Just because a metal detector has a non-sinusoidal (usually square wave) TX waveform, doesn't automatically means it's a PI.
Oops!
I replied to Dave's post after reading, and then found there was whole second page of replies on the same subject. Blimey ... this thread has become popular.
Oops!
Well we have been here before in the GPZ7000 thread.
BBS/FBS and the GPZ process information in the time domain, same as PI.
BBS and FBS extracts X and three different bands of time constants, this is obviously different to VLF which processes info in the frequency domain.
BBS and FBS have a period where X can be extracted relatively free of the target signal, there is no such period in VLF.
The method of target excitation is similar to PI and quite noticeably different to VLF.
1. GB and discrimination are known features of metal detectors and their combination already exists in the prior art. Therefore such a combination, per se, is prima facie not inventive. You can't appeal to the combination alone to claim inventiveness.
2. As a consequence of (1), an unexpected, surprising synergistic effect should be present in the combination in order for it to be considered inventive. The effect must not predictable by the person skilled in the art when combining the known techniques disclosed in the patent. However, no such effect is present because GB and discrimination are completed separately and sequentially with no mutual interaction and doing exactly what the skilled person expects them to do, nothing more.
Contrary to what you pretend, there's no transformation of GB signals to TC spectrum. GB is treated first by a known method and completed, then TC by another known method starts. There's no interaction. This sequence is the normal procedure in previous combinations of GB + discrimination, therefore the combination is obvious.
Obviously the examiner didn't have the time to find the relevant prior art and do a meaningful substantial examination. The quality of the US patent office is as good non existent, they just rubber-stamp whatever is submitted to them.
Let's look at the prior art.
Eric Foster etc cancels log-uniform VRM whereas Minelab cancels saline + log-uniform VRM or log-uniform + log-linear VRM simultaneously, ie, with one setting of the GB.
Take the latter where Minelab cancel the ground and a hot rock simultaneously. Try to form a logic flow chart that will accomplish this without referring to ML's patents. You could GB the ground (log-uniform VRM) with any of Eric's or well known methods but the output of this channel is effectively filtered DC and can't be processed further. You could form a second GB channel for the rock but you end up with a lot of noise and no gb if you mix them. You could switch when you encounter the rock but the real world is different because the ground also has a log-linear component and you would just end up with a lot of noise.
Now take various methods of TC discrimination. The TDI TC disc works but only if the ground is mild enough to not require ground balancing, ie, the GB control is then used to set the pivot point where it would result in horrendous ground noise if the ground is mineralised so it's obvious that Whites couldn't or didn't try to figure out how to disc and GB at the same time.
You say "GB is treated first by a known method and completed, then TC by another known method starts. There's no interaction. This sequence is the normal procedure in previous combinations of GB + discrimination, therefore the combination is obvious".
Well if the output of the GB channel is effectively DC with no TC information then I suggest that the combination is definitely not obvious!!!
Physics work the same for both.
i ask again you - is there THE DELTA PULSE on coil of Fisher Impulse or NOT? DO NOT PLEASE REFER TIME DOMAIN AND
RECEIVER METHOD be cause no relation to PI.
Good grief, kt315, you've been here ten years and still don't know what pulse induction is? You've already seen the Impulse voltage and current waveforms posted in this thread. If you want to know the circuit, use the search window, you've already been told the schematic is on this website. http://www.geotech1.com/forums/showt...0572#post80572 See? And here's the patent: http://www.google.com/patents/US4868504 The patent even explains how the thing works, who'd have ever expected that?
Reason: utter amazement......
The BBS system transmits continuously with no periods during which reactive voltage is zero. Therefore it is not a pulse induction transmitter: it does not and cannot support a pulse induction type receiving system. The BBS system has this in common with the Fisher CZ and White's DFX systems, and it is what none of the aforementioned "VLF" (whether frequency or time domain) systems have in common with any pulse induction system including the GPZ.
