Magnum on steroids!
  • amtech2005
    No problems NOW !!!! Nikko, But My email is [email protected]
Name:	its ok now..JPG
    Everything is ok with Sprint and pcb now. Now i'm just trying to find correct and final schematic for Dual Frequency Golden Mask 8 and 18 khz
    Thank-You very much Nikko .
  • nikko10
    I will not understand in what problem???you can not open the file of LAY??? Write to me on my electronic address and I will send to you LAY 6.0.
    [email protected]
  • amtech2005
    Thank-You Everyone.
    All the files .lay files are working on Sprint Layout 6.0 !!! Sprint 5.0 was not working on Windows 10, LOL !!! Sprint 5.0 was 32 bit maybe ?
    Best Wishes to Everyone ..............Eugene
  • nikko10
    Winrar .For me windows 10 is too set and all works perfectly
    Setting of stabilizator on a pay-Click image for larger version
  • amtech2005
    Is that 7 Zip or RAR file ??
    Can not open file , LOL . 7zip or Winrar ???
    Thank-you Nikko for your help. The best things in Life are always the hardest to get done, my computer windows 10 is never working right , good old microsoft !!!
  • nikko10
    Golden Mask 4 DIP FINAL.rarHere is the board in the DIP, stabilizer circuit, if you need to replace the L7805
  • amtech2005
    Anyone have this in sprint layout or .sch or .pcb
    I got error and could not open in my sprint 5.0 . Maybe I need 6.0 ?
    I do not want smt . I want through hole. Easier for my eyes and i solder better when I can see !!! LOL
    Thank-You
    Eugene
  • Wiltran
    Thanks Timekiller! yes that has to be right because I looked up the schematic for Gold mask 5 and it shows that it connects to the frequency switch center connector. I am going to try that today because the way I have now it seems like a dead short... no reading on the frequency counter.
  • timekiller
    On collector Q7 .
  • Wiltran
    GM4 coil
    Originally posted by perkun View Post
    My Magnum also works great.
    The THT board is checked and working properly.However, the author of the topic made a mistake with connecting the coil.
    When I started the detector according to recommendations from the forum the detector worked very bad.
    The third coil that is responsible for BG and DISC should be a separate winding not continuing TX!
    Correct coil connections are shown in diagram GM5
    [ATTACH]39849[/ATTACH]
    Can anyone tell me what pin 5 on the coil connects to? I am building a GM4 coil with the extra TX winding.
  • timekiller
    No, this diode SS14 has a protective function . Should be at the beginning of the 12 volt line , at the top left corner is not diode . 100 mkh inductance or 10R resistor .
  • Wiltran
    Timekiller, thanks for your help. One more question, is the SS14 diode the unmarked diode at the top left corner of the through hole board design?
  • timekiller
    No . highly recommended for stable operation 12v .
  • Wiltran
    Originally posted by timekiller View Post
    this is the PCB last revision I can find
    Does this circuit have a voltage doubler that allows it to run on a 5V battery?
  • timekiller
