What md should I build next?
    hello qiaozhi thank you
    for your advice
    i want to build krot but i think i will leave it until i have more experiance
    i think im going build the tgsl
    who is selling the kits?
    ithink silverdog sells them do i need sepparet pcb for vdi mod
    thank you
    regards dean
      The prices are the same between tgsl and the krot2.
      The krot2 coil is much easyer to null. If this is yoour first vlf,
      It will be easyer to make it work.
        for your advice
        thank you
        regards dean
        The kit is available here -> http://www.silverdog.co.uk/shop2/ind...&product_id=99
        Silverdog doesn't supply PCBs or kits for the VDI option.
        There's a 7-inch 5-pin widescan coil on eBay at the moment which is suitable for TGSL. BIN price is £50 with free postage. Plus it comes with a coil cover.
        http://www.ebay.co.uk/itm/TESORO-7-I...4AAOSwOdpXzGaT
        The same seller has a few similar coils for sale, including a couple of 11-inch widescans.
        I would build TGSL first, then figure out how to build the VDI later. Once you know how to program a PIC to read the ADC inputs, and output to an LCD, the rest is fairly straightforward. The technique of target discrimination using phase demodulation is described in ITMD.
          Hello qiaozhi
          thank you
          is pic programming same as doing a sketch on Arduino?
          i thing I am going to buy the tgsl-edu
          can I ask what the edu?
          regards dean
            Hello qiaozhi
            thank you
            regards dean
            Edu - means Eduardo1979, guy who redesigned pcb a little bit.
              Hello cdi
              thank you
              i thought it might have something to do with the circuitry
                regards dean
                It's about the same. You can also programm PICs with ARDUINO if you have a UNO board waiting for job.
                https://forum.arduino.cc/index.php?topic=92929.0
                You can build a TGSL which has ONLY one tone. You can add a two tones mod. You can add VDI mod.
                Or you can make KROT2 project which already has everything you dream of. But TGSL is a very nice project.
                  U can also make this Quasar Avr, which is DIP component and very similiar to Krot project.
                  Multi tone, feritte calibration, nulling coil without scope or multimeter cause there is ac voltmeter inside machine.
                  If u have problem to read Russian, i can post files for you.
                  http://www.radio-magic.ru/images/art...eshnij-vid.jpg
                    Hi reptooyepi
                    thank you I do have 2 uno,s one has dip chip in the socket can I program it and remove it and use it for krot ?
                    and one has smt chip
                    Regards dean
                      hello cdi
                      thank you that's very kind of you
                      where can I buy the pcb or can I make the pcb?
                      been wanting to try etching pcb's
                      what coils can use?
                      what kHz ?
                      Krot? Tgsl? Quasar? which is best for iron infested soils because uk as a lot of iron minerals in soils?
                      Regards dean
                        i got one order on King Cobra... people are on Bara-Marauder-3 too... but i have slightly to change both... after that i will order batches... all winter project's orderers will get winter project before winter going...
                        http://storage9.static.itmages.ru/i/...79ceb425b9.jpg
                          hello cdi
                          what coils can use?
                          what kHz ?
                          Regards dean
                          I don't know about Krot or Quasar, but Tesoro detectors are well known for their ability to work in UK iron-infested soils, and are especially good at detecting small hammered silver coins.
                            only reminder. i have only direct output on Spectr author http://kusav.chat.ru/spektr_const.html
                            if you are not in course -
                            Clone PI=Koschej-5I/IM --- Andy_F vs Schedrin
                            Spectr=Koschej-18 --- Kusav vs Schedrin
                            I SAY AGAIN - AUTHOR OF KROT IS NOT ADEQUATE GUY AND VERY CLOSED FOR SOCITY. you can NOT get a help from him if you
                            will meet a problem.
                              hello cdi
                              what coils can use?
                              what kHz ?
                              Regards dean
                              I will post files later cause im not at home right now.
                              Well, for iron infested area's, there is no faster machine than Xp Deus, no doubt. But there is word about diy. For iron infested area, tgsl will be good, it has very good recovery speed and it is realy good in rejecting ancient rusty nail's.
                                That's why the community forum is made for..
