What md should I build next?
  • #31
    That should work but i've never load hex file with arduino, only sketchs.
    The simplyest way is to buy a usbasp for 2£ on ebay. Thdn, you can use many progras, even arduino with standalone chip.
    I'm not sure that the bootloader of a standalone chip is compatible with krot hex file.
    For the krot2, the only way is to buy SMD ATXMEGA32A and usbasp won't fit it.
    You can use arduino as a pid programmer to program your KROT2.
    I can also programm it for you for the price of the shipping cost.
    • #32
      Hi quiozhi
      thanks you
      I just wanted to build one that's small and compact.
      i thing the tgsl is big pcb which means big box
      i wanted one light weight so much choice
      regards dean
      • #33
        Quasar AVR
        Ok, here is Quasar AVR:
        Here is site where u can find more information's, on the first page is ARM version, which is smd, but dont wory, they work almost the same.
        http://www.miriskateley.com/samodeln...-svoimi-rukami
        • #34
          About coil, i just copied what author wrote:
          Coil type DD 230 mm outer diameter. TX - 40-45 turns of wire 0.5 mm and RX - 200 turns of wire 0.2 mm. Winding TX switched to the metal detector with the serial resonance capacitor 0.3 mF, the resonant frequency of 8.192 kHz turned out, the RX coil is switched to the metal detector with parallel resonance, and is tuned to a frequency of 1.5 - 2 kHz below the resonant frequency of the TX.
          • #35
            If u don't like pcb for TGSL, take a look on this Tesoro Eldorado, i'ts a litlle bit smaller than TGSL...
            • #36
              Originally posted by CDI View Post
              I will post files later cause im not at home right now.
              Well, for iron infested area's, there is no faster machine than Xp Deus, no doubt. But there is word about diy. For iron infested area, tgsl will be good, it has very good recovery speed and it is realy good in rejecting ancient rusty nail's.
              Hi cdi
              thank you
              i would like to like see what's what.
              to be honest I would love Xp deus but I thing the price of them is to high.
              I would pay that if it could dig up the finds
              Thank you
              regards dean
              • #37
                and... TGSL redesigned by user Blobber, also smaller pcb than 3.0 version.
                • #38
                  Hi reptooyep
                  thank you that's really good you offering to do that if I need it I will call on you thank you
                  I will look on eBay
                  regards dean
                  • #39
                    only reminder. i have only direct output on Spectr author http://kusav.chat.ru/spektr_const.html
                    if you are not in course -
                    Clone PI=Koschej-5I/IM --- Andy_F vs Schedrin
                    Spectr=Koschej-18 --- Kusav vs Schedrin
                    I SAY AGAIN - AUTHOR OF KROT IS NOT ADEQUATE GUY AND VERY CLOSED FOR SOCITY. you can NOT get a help from him if you
                    will meet a problem.
                    Hi kt
                    thank you for the advice about him
                    I really trust you I have bought from you before and you do very quality pcb.s
                    thank you
                    regards dean
