Originally posted by Skippy
V1 is a zero-volt voltage source (a shortcircuit) that's used to monitor the coil current. This is used as input to the H element (current-controlled voltage source). Then an E element (voltage-controlled voltage source) has an attached polynomial that multiplies the voltage at the X node with that at the Y node to calculate power. The graph facility will then let you run an FFT on the Z node.
