Originally posted by kt315
A Loop search criterion in the initial testing was of a spider with a capacity of
about 350uh and about 1 ohm resistance.
However, due to the possibility of adjusting the pulse width and delay and
integration in this circuit, there's actually possible to use a wide range of loops.
However, it's recommended to make a stronger pitch of the loop spider or flat like
this, to answering the separation and iron reject.
For proper functioning of the separation and iron reject, automatic Delay of loop
must be about 20 and if the delay be much higher than 20 the separation not
working properly.
Shielding the loop with graphite spray can be useful but not the right answer
with aluminum foil and metal detectors range will be low certainly, unless a very
thin coating of aluminum was used as a metal itself almost by metal detectors
cannot sense!
Cable of loop is also very important .Recommended loop cable to connect the
circuit of the brain that is high quality stereo Shield and the Shield on. The anti -
noise microphone cable tests MAX brand to have a good result.
connect the cables to the circuit in this case is that the brain stereo shield the
cables were connected at the beginning and end of the point -to-point cable shield
2LOOP attach some 1LOOP Contact field.
In fact, this method cannot use the Shield. It also tests a good answer, and given
that it may be appropriate stereo cable shield away, was the method used.
The exterior loop into the cable shields up.
Delay is the essential to note that much of the lower number, as well as cable
loops will find a sign of higher quality! However, should this test was whether to
close its metal cable or cables shaking, the reaction was shown or not? If the
cable does not fit! As well as cables with aluminum foil are often not appropriate.
If you use a 3-pin connectors and plug type military's recommendations. Of
course, of course, should not be near metal connector plug and use loop or loops
Metal Detecting will have a negative impact on performance. It may that plastic
connectors has a better answer.
