And the correct supply voltage has to be taken.
Surf PI Micro Var. 1.00
At gate of MOSFET is Pulse@ 640Hertz, which is the correct pulse repetition frequency (PRF) for surf PI. You must measure this point only on oscilloscope to see waveform of signal. You need to monitor the voltage at the negative rail. You need to use good healthy batteries or power supply of 12 volts. You should have put in MOSFET and coil, then look for correct voltage at the negative rail, BEFORE putting in any other chips. This is because you need to know your rails are not sinking as a result of loading of the circuit by MOSFET and coil. Since the negative rail is taken off the gate junction. A sinking of the voltage could indicate a weak battery or power supply.
Remember not to limit the current on your PS module.
@dbanner,,,Yes, it's a pity,,,Mind you, I have learnt a few things from the thread about it before I attempt to build the pcb that Silverdog (Andy) kindly sent me. I notced on the 'Ads/For sale' that BKY1337 is selling his boards and says he hasn't finished buildng his yet? I may start building mine soon and see how far I get with it,,,Regards, Marty
