"The BLUE signal is the pulse that generates the slope"
So you know when the slope will occur. So, as per my previous suggestion, start a negatively sloping waveform generator at the correct rate, sum it with the actual rising slope, and you have a near-flat waveform. Use a later trigger to see if the 'flat' voltage is the same near the end of the ramp-time as it was at the beginning. Maybe a sample-hold is needed at the beginning, to compare against?
