Originally posted by bklein
View Post
How does a manufacturer test a detector?
I got permission to go detecting today and tested again the detectors in wet sand. I screwed up. The ring is on edge because of the way it is attached to the string. The GP Extreme and CTX still detecting it at impressive depths but the surf PI’s don’t. If I insure that the ring is horizontal it is detected by the pi’s 10-12” in sand or on top of it. I guess that agrees with the majority of reports.
Twin overlapping loops. Subtracting outputs of the two coils at front end. Then only single gate needed for timing switch.Originally posted by Qiaozhi View PostI suspect your idea would only work if the signal created by moving the coil in the Earth's magnetic field was always the same. However, the signal will change depending on coil orientation with the magnetic compass. Also, the Earth field elimination process removes external EMI.
That was the way purportedly used in the Treasure Seeker by Crone.
Supposedly cancel out ground effect and medium, long wave EMI .
No mention of Earth Field.
"I'm designing a MPP mod based on this principle", Thats interesting newsOriginally posted by Teleno View PostUsually a PI samples at 1000 KHz, the sweep speed being 1m/s. The displacement of the coil in 1ms is 1mm, negligible enough to consider the EF signal as a DC offset within that millisecond. The same applies to EMI at 50 Hz. I'm designing a MPP mod based on this principle.
