CIAO CARL
    I also think it's a BDxxx
    And I agree to ask Detech
      grazie ivonic non ho familiarit? con queste cose forse se puoi darmi un grande aiuto per scoprire qual ? il tuo transistor
      Non riesco a capire che sei un vero amico ivonico :stelle:
        This is the 2nd time I've had to tell you.
          thanks ivonic i am not familiar with these things maybe if you can give me a great help to find out what the transistor is
          I cannot understand that you are a true ivonic friend
            Try to trace out only that part of the pcb, see what are the connections. Locate power lines.
            Draw on paper and post here.
            Slim chances, yet possible to figure it out.
              Ok, sorry
                thanks i'm see if i can
                  > Collector is always in the middle.
                  And nobody corrects him.
                    Buy some flux/rosin and learn to use it. No more of this ****.
                      one important issue. do not buy from company that does not answer you. forget detech and do projects
                      on the site. you pay your money for what? if i sell boards i answer at night and at day.
                      i see this board first time in my life. yes, i beleive it is DP based sch. but in your hand
                      you are able nothing. you can not desolder board, yo can not draw layout, draw sch,
                      you can nothing. so you must give out this board to another men who CAN. i fear every movement
                      of your hand on this pcb... you put new problems in the board by every your touching of solder iron.
                        Sad but true
                          yup. she can.
                            ok
                              What was that poison I just watched ??!
                              where do you find these things I wonder ?
                                I had a chance to repair a ssp-5100G coils a while back and I have some comments for it.
                                take a look at the pictures first:
                                the fault was coil cable and connector, anyway
                                the first is first, Sensitivity == my home made Polones PI which i had at hand with same size coil for both.
                                which is disappointing considering the Price (more than 2000$)
                                super slow response time just like Polones
                                controls:
                                Delay: doesn't represent any values just says min / max when you push it and God knows what that refers to...
                                Volume: it's too load and you can barely feel the change over the entire range of adjustments.
                                Auto: Super slow SAT if i remember correctly
                                Reset: //RESET (it's one of those programming comments)
                                Depth: effects a bit on sensitivity
                                Detect: "Not Sure".
                                Tuner: it was like a lucky wheel which you would press and get a random number to work with in the field. "Not Sure"
                                ON/OFF: Now this one is legit, it actually turns the device On or Off, but only when the coil is attached which is annoying if you just want to play with the menu in your room, alone.
                                DISC: you push it and it goes On or Off, and when it's ON it can detect a nice chunk of black Pure iron bar just as good as when it's OFF. so overall "very useful"
                                Light: and finally Yes they actually can blink the LED
                                and the Graph, Yes it's just a sound to Graph converter, like a special sound recorder.
                                I had some field experience with it the same day and of course it doesn't have GEB so very sensitive to ground keeping in mind the high coil peak current they used.
                                battery life suckes, maybe an hour and a half or so
                                really nothing...
                                i'm still shocked by Price/Performance ratio.
