c.scope cs9000 HPX
  • surfdetector
    can't unscrew HEX screws on coil ((( it is unstandart -! not 3 and not 4mm bites. something near 3.5...
    must grind out one... or it is in inch standart???
    Yes it will be inches. Most likely .125" if you say it is close to 3.5mm.
  • kt315
  • kt315
    welcome. i hope with my info you will get the end result. i soldered all back now and will search the coils.
  • Jose
    KT315, Thanks for the photos, I built this detector some time ago, with some doubts and improvisations. The images are very useful to me.
  • kt315
    invisible track
    a way of grounded: -Batt --> 8 pin U1 --> rotary switch housing --> detector housing.
  • kt315
    check a BOM
  • kt315
    invisible track
  • kt315
    yes i will desolder rotary switch. it hard work but possible. for desoldering of phone socket i did special nozzle.
    i also got TM-808 in repair.
    i found a problem in C-Scope, it is the pots. they are lost a contact, in sound devices we say that as 'noised pots'.
    but i did not find same type in ali for order, with the long pins. must repair.
    i do not know a place where to find same rotary switch. its very specific.
    i compared all components with the sch and all are matched, just two resistors seems like mixed up.
    will tell later.
  • chafik
    thank you for sharing .can you please desolder the rotary switch and take picture or if you know where i can find it send us link please
  • kt315
    i put files in an album if someone does not see it. after some time i will
    delete them. https://www.geotech1.com/forums/album.php?albumid=136
  • kt315
    Originally posted by mmh View Post
    Hello
    In the schematic cd4069 does not exist
    look on right side from IC3, #14 o-scope pic.
  • mmh
    Hello
  • kt315
    thank you Melbeta for the connection. yes, we have TM800 sch and it is very same
    as i see. this is Rev E board and thinking it is last done before a closure.
    pleasure
  • Melbeta
    The Discovery TF-900 was originally built for Whites as TF-800 model. They had some kind of parting, and Discovery quit building the TM-800 for Whites, and Whites then came out with their own TM-808 model. So if you find a schematic for the TM-800 model, it should be identical to the TF-900 Discovery model.
    Melbeta
  • kt315
    pcb pics
