Hi Eric.
It is all truth. I am not such expert for Pi-mineral problematic. On my test polygons I have alluvial soil with relatively low mineral content, I believe. Also I have collection of lot of different hot rocks. In past years, I was tested lot of commercial Pi models, like Puls star ll,lll, Lorenz5, Sniffer, DeltaPuls, Superscan etc, and also couple of my experimental design. Most of them, totally ignore hot rocks (probably because they small). But they all are always gives strong response to my ground. Shield, also wasn’t help much. As is impossible, to carry coil always on same distance from ground, Pi units works quite unstable. With such work, weak signals from deep targets become same like ground signal variations. This statement is coming from real field work, not from theory.
Ground and rocks indeed makes serious phase changes in Tx signal from IB coil. But with adjusting of phase angle, is possibly to easily cancel it. And with processing of two or more independent channels, is possible to cancel anything you want. Also, Rx - LC with usually high C (in comparing with Pi), and with good shield are become totally inert from any capacitance changes. With Pi method, is impossible to get such stability for capacitance changes from ground, probably because of very low capacitance of Pi coil.
As I understand, such Pi-Vlf debates, only advantages of Pi detectors is Hi power Tx and large coils, which means possibility of deeper search.
But, Vlf also can work with extreme Tx power, and with large coils.
Zeljko.
Zeljko.
