Originally posted by Unregistered
PI's do not measure phase, although there is a relationship between the decaying target signal and the phase response of a sine wave system. Scan a PI over a ferrite core or rod (provided it is a magnetically soft ferrite) and it will give no signal. Scan a balanced coil sine wave detector of the same ferrite, and it will give a large signal, that is, until the phase detectors are adjusted to the null point.
In practice, soils and rocks that contain magnetic minerals are both permiable and have magnetic lag. Now, magnetic lag shows up on a sine machine as a frequency dependant phase shift, so you would have to dial in some additional phase compensation to null this. The amount would depend on the operating frequency of the detector. Add in soil conductivity, wet, dry, or salt and you have quite a complex sum of different and varying phases to sort out.
PI's do not respond to purely permiable targets, or to ground conductivity, unless it is sea water. What you are left with is the magnetic lag, which decays away, similar, but not identical to a metal target. Most soils and rocks have a permiability/viscosity ratio which is constant between certain limits. This higher the viscosity signal, the higher the permiability, or susceptibility as we call it. A straight PI cannot be used in most inland areas of Australia, because of the viscosity signal, and even the Minelab SD's and GP PI detectors, with their auto tracking ground balance circuitry are unuseable in some extreme areas. This circuitry balances out the viscous signal but the permiability of the ground is still there, and doing everything it can to prevent the TX signal reaching the deep nugget, and the return signal getting back to the coil. Hence the extension of thought to a ferrite pot.
As far as has been reported to me, even the strongest mineralised ground in the US, does not approach that in much of Australia, and it is purely ferric oxides that are responsible, with little or no metallic iron content.
Eric
