Cache Test
  • tonemgub
    did you use silver US quarters?
    no I use 30mm 5 dinara Milan Obrenovic IV
  • sinclairuser
    Originally posted by Koala View Post
    I not tried one myself. But I have been out twice with people using the Beast.
    Both times once in the Peak District (I was using a Bandido with no problems) and the other in Shropshire (I was using an IDX with no problems) the owners were having problems.
    Having to re ground balance several times and false signals. They really were having a bad time. The Peak District was water logged ground but the Shropshire one was fairly typical of around here with plough shear mixed in with coke
    Out of the 20 to 30 people taking on each rally their finds rates were towards the bottom of the scale.
    That's not to say they are bad. After all it could be operator error, just bad luck or the detector just doesn't like the type of ground we have here.
    I have never really understood blisstool as a company, the ltc27 and the ltc42 were great no nonsense detectors, but the company only seem interested in "the beast", not selling a lower spec model just seems daft to me I have heard people say "I liked the earlier simple models".
    so they are missing out on sales granted not a huge amount, but if they reintroduced the ltc27 as a base model and only sold 200 a year it would still be money in their coffers not the competition, as I understand it they are made in low volume quantities, so building a few of these for every ten ltc64's to me seems a no brainer.
    especially since the folk who would buy an ltc27 or ltc42 are not the same folk who buy the "beast", they probably assume if you want a 42 you will buy a 64, which is totally wrong and just leads to lost sales.
  • kt315
  • tonemgub
    in plastic bag
  • kt315
    you put the coins in metal can. detector reacts on the can. no secret.
  • tonemgub
    I tested 50 silver coins with Relic Striker and captured them without any problems at 70 cm
  • erte123
    i anyways don't think the bliss can hit a quarter at 24'', not even a tdi pro with a 16'' coil..maybe 20'', i think only a modded gpx could hit it
  • Koala
  • sinclairuser
    blisstool detectors are so 2012, tried an ltc64x, didn't like it found it harsh and chattery, also thought it felt heavy for a "modern" detector.
    mate of mine has an ltc48, and to be honest i like it much better less knobs and switches, also the box on the stem and the battery pack under the arm cup feels much better kind of like a fisher 1266, still heavy(imho) but managable.
    so take that honest opinion how you like, blisstool sold loads and loads v3 64's and you would think that they are plenty full at a good price, but you dont see as many for sale as you might imagine, and by the same token i dont see many in use at rallies and such, so those that buy them hang onto them even if they dont use them that much.
    i think people love the detector, but not setting it up and using it all day, no doubt its good but it has quirks, its a "marmite" detector you like it or you dont.
    but if you are really interested try it first, dont just jump in you might find its quirks outweigh its benefits.
  • erte123
    anyone test a blisstool v6?
  • Funfinder
    One pretty realistic test would be to mix up little copper penny coins
    with clay (50-50%) and forming soming 5-7 cm diameter ball.
    Because a real cache with 100 to 200 coins put into some clay-pot
    and buried 1000 years ago also wouldn't be much larger.
    For spread vs. single stuff some iron-plate 20x20cm at one place
    and small, single, not each others touching iron nails spread over the
    same sized area at another place would tell the difference.
    However: Usually the corroded coins just sum up seen from their
    total metal weight and surface area (like Yagi-antenna elements)
    concerning the complete induction-strength of the cache.
    So the coin-mud-ball will have its highest induction at the middle.
    But this doesn't matter a lot because its just a few cm lower.
    Much more important - I would say - is to check out which kind
    of metal is how good detectable at what kind of mineralization.
    Coins which contain copper, nickel or zinc are easy detectable in
    desert sand but not if it comes to high mineralized areas and if
    those coins are included in some clay-pot.
    Silver coins give the highest contrast factor but caches including
    them might be more rare to find. Gold even more.
  • Nexus
    Originally posted by markg View Post
    I'd like very much for you to do another cache test. Eleven years later and newer technology.
    It seems like I'll have to do just that. I have a small hoard of Roman coins 1 kg, 445 pcs. all seriously decayed. I intend to make a demo video of MP getting those at 60 cm (24") under compact soil and with just 13"DD coil, but the trouble is the damn digging work. A proper test requires much more than what is described on Gary's web site.
    This demo test will require a large pit at least 1 meter deep, to allow a proper hole to be drilled at 60 cm from the top soil layer in parallel position to the ground surface and deep in the pit's wall, at least 60 cm or so. In this way the hoard will be out of pot holes interference way.
    Two years ago I have done this test set up, but last year I got the hoard out of the ground as some small iron pieces came out of there and was not sure who is getting what and I needed to see for sure if the PI's can do something about this test. So the Iron that I found upon recovery of the hoard have spoiled the fun and for now I believe the PI's were getting that Iron and not the hoard as the Iron was way closer to the surface.
    The VLF's with bigger coils were getting very good signals with positive discrimination, but with 13"dd coils the discrimination was confused by the Iron bits.
    The MP with 1 meter concentric coil is literally blasting this hoard with at least 20 cm above the soil.
    Hopefully not long from now I'll bury this hoard again in more accurate set up next time.
  • Funfinder
    It's not that important because we already know which detectors are good
    and of course searching for a deep cache means using some larger coil.
    You even could put a big metal object on a shelf behind a high
    mineralized brick-wall to simulate the ground resistance at some degree.
  • Mark-VA
  • Funfinder
    Its nothing, just my 2 cents or better: my buried beer-caps!
    If you have the chance to built some "underground test-gallery" I guess it would be the
    best because you can use it over and over again, you even can fill the plastic pipes
    with finds and stuff all together and you can demonstrate different detectors to others.
    Just the pipes have to be long enough (ca. 2meters) so the finds are really down under.
    You might need some special hook to get them back and to close the pipes on the inner
    end so no find gets lost.
