Cache Test
    moodz has to read.
    I would be good if there was a "score board" spread sheet with detector type, cache type, depth and 3rd party verification.
    Also some "standard" caches that can be made up from common items available globally and / or cache simulators.
    • Originally posted by Riss View Post
      an acquaintance shared - he has a test field of loam, very dense soil - it holds the water in a hole for a very long time. the buried pot gives a weak signal when the soil is moist, but the signal disappears completely when the soil is dry. The pot of coins was buried more than 17 years ago. measurements were made with a Minelab gpx 4500. what caused this ? ​
      :detective
      Hello
      The same thing happens to me...
      Winter has a signal.
      Summer has no signal.
        This year my colleague and I did testing on buried deposits,, 10cm ceramic pots /Olla/ with targets... buried at depths of 50cm, 65cm, 75.cm, 82cm, and 100cm..
        Another 10cm metal cup /Olla maciza/ at 110cm..
        Other targets are Roman sestertius coins at 40cm, 45cm, 47.5cm, and 50cm and Roman silver denarius at depths of 30cm and 35cm..
        test field is 2 years old​..
        Among other things, there are control targets buried there.. a flattened Coca Cola can at 85cm and 110cm..
        and also 4 iron targets at 50 cm deep...
        The terrain is challenging - conductive.. this makes detection difficult.. and many detectors will not see the shallowest deposit at 50cm..and the Roman sestertius at 40 cm ..and Denarius at 30cm../on Discrimination VLF/..
        as a reference detector here appears AKA INTRONIK with 18"Coil 2/14 kHz...but also coils 15" and 13" 2/14 kHz can give good results..
        ​https://www.youtube.com/watch?v=FGVcloY9ri4&t=0s
        Click image for larger version  Name:	Test terrain. ES.jpg Views:	0 Size:	118.5 KB ID:	435738
        • Now let's get back to testing for deep deposits...on Another test field./Top Digin/.. which has several different deposits at good depths... since we tested different detectors and coils for 3 days... we did several tests specifically for detecting deposit targets..
          Here is one of the tests...
          The first three targets are Roman denarii at 15,20 and 25 cm,,
          the next targets are various deposits up to 80cm deep and also 2 deep highly conductive coins..and a military buckle at 55-60cm..
          an interesting test was also the test for masking a 500 gram silver deposit at a depth of 80cm, with a small iron nail on the surface of the ground,,​
          • Any test on bottom of a man made hole is false even after 10 years past, because soil does not settle in those holes by mixing with the surrounding soil.
            Signal in the winter, but no signal in the summer means false signal in the winter caused by increase of conductivity along the hole walls.
            Hoards made out of common targets have nothing in common with Hoards of ancient coins. The modern coins/targets are much better detected by both PI and VLF technoltechnologies due to their impurity of alloys resulting in relatively short time constants (good for PI).
            Ancient coins, especially the bigger ones, have longer time constants that get closer to the soil vector, which is what makes them more difficult to detect at depth.
            Also all Ancient coins in any hoard without exception are electrically isolated from one another making it ever so difficult to detect.
            Lump of modern coins is much the same as a big lump of metal.
            A hoard of Ancient coins is nothing a like.
