Cache Test
Let me think this over. Really great information as usual Funfinder. I really appreciate your posts.
Salute landman!
If you have some 3 - 5.000 bucks I'd also add some priceworth Easy Rad GPR to the deep-detectors collection
because that way you also can get super cavity-tests!
The idea of course is fantastic - reminds me on the test-stone-wall-bridge from Makro & Nokta at Istanbul!
You can't test different e-smog situations but you can create sandy, loamy, brick-stony etc. layers.
The most simple and perfect way would be if you have already some "hill" nearby.
You cut this hill from one side vertically down or you built some 3m broad and 3m deep trench.
Now the method of course would be that you plug into the hill different thick plastic-pipes.
So those are leading 1-3meter deep inside the hill.
Because its pretty really useless if you bury silver bars etc. - it's like you will lose them.
And for demonstration and video-clip purposes it's also better if you can insert stuff
inside the pipe at different depth levels how you like it.
If you built such trench with a mini-excavator it would be the best to cement some wall
for stabilization, too, so the earth and ground doesn't gets loose.
And afterwards you can prepare the surface below the grass with different stuff like sand,
loam etc. - this way you can test different kind of soils or imitate them to some level.
The whole site should be at least 4 meters long and if you wanna built some large cave
for cavity tests better 8m. You can also built some stairs which go downwards,
at the beginning are the hole-openings for the smaller and not so deep pipes.
But it really depends on the area where you are living - if it's not too rocky there
you can improvise and will find some way.
And if you really just wanna bury stuff better use some alu instead of silver
and: copper instead of gold - even cheap X-large selfbuilt plates made of Alu or copper-foil
will work.
My test-cache consists of ca. 200 beer-caps at ca. 70cm depth, spread over ca. 15x15cm diameter, below loam.
But it already shows really good which detectors with usual or larger coils can find it and which not.
The only drawback is that first I have to drive 3km to reach this test location.
With the Jeohunter and 45cm coil I could find a 9cm cannonball at 60cm depth below loam and
sand but this was already not easy. Just to show some relation of the "usual" limits of detection.
If you want it the easy way, built three 10cm alu-foil balls and bury them at 70, 90 and 110cm.
Only the best detectors will still detect it at 110cm!
Larger test-objects should be a little bit deeper of course.
You can bury some old 35x40cm tools-alu-case at 1,5 - 2 meter
so you'll get some great simulation of a real huge treasure-cache!
Hi Funfinder, I want to create a test garden for larger objects. No coins. Ok maybe a 1oz silver coin is the smallest. Help me design a test garden for the likes of the Deep Hunter, Golden King, DRS Ground Exper and the like. Already I've collected the following metal objects: 1 kilo copper, 1 kilo brass bar, 1 kilo silver bar, 1 pound aluminum bar, 1 pound zinc bar. I do not have a cup, plate or bowl made of silver, copper or brass. I do not have anything representing steel. At the moment I have one aluminum can buried at 80cm in my garden, that's it. What do you suggest?
Hi badran,
soon you can try the Nexus with 1 meter coil or the already existing Makro DeepHunter (also 1m).
btw. is the winter-time good for treasure-hunting in Lebanon or is it forbidden everywhere anyway?
hi to all........i thank you all for this nice chat....in 1995 i went to a greek site with 4 locators gimini 3 and 2box garret a metadec 3 cscope and pi cscope ...i found a lot of large targets like bronze jugs but only after the beldozer took between 50cm and 3 meter from sites b4 i came few years ago...targets were like foot a ball size and larger,,,they fail all...so i made a 0.48 coil for pi and found a jug at 73 cm that was not seen by all metal detectors....and spot 2 targets and kept them there...till now...one month ago my pal payed 8000$ for 2 metal locators so i took him there to test....trash lcd hunter failed and sound on cigaret foil....ha ha ha.....dam...i can write a book of my old treasure hunting.....yes the coin cash are not unified field and ground will make the signal weak.....
Has anyone tested a minelab GPX series detector on a cache target?
It's really interesting how it performs as it's not yet another VLF/PI detector
and it claims to be deep.
I read the entire thread and learned some valuable lessons . I do have a few questions though
in regards to cache or hoard detecting if the experts donot mind answering.
1) what metal or combination of ions buried at least 3.5m could give off a halo effect that a minelab 705 (my only detector) could pick up ??
2) I have had a pinpoint on it from -1m before that it was just sound. Im at -2m now and the minelab is reading at the two ends of the TID. Im getting a -8 which is the lowest on the negative scale and +44 +46 + 48 on the other side. I got a few flashes of +20 +32 at some point but lost them later on.
3) Im getting a little bit of a null but it dosent seem like much. Something like a rusty nail .but the signal is really deep. Im thinking if it was just iron, I wouldnt have the + TIDs.
Seeing that this is all relevant to scientific purposes, if anyone can shed any light, it would be greatly appreciated.
Thank you
As an afternote, I think IF its what I hope it is, it shouldnt be more than 65 years old. Would that be enough time for a metal to send such a signal ?? And from the pinpoint, if I guesstimate the depth at another 2 meters, I would think it couldnt be more than 70-80 cm long by maybe 40cm wide. But I may be off on the depth. I cant be sure yet.
Interesting that he found 11KHz the most suitable frequency, I would have expected 4kHz to be better, based on the individual coins. It would be interesting to see what an experienced Deus user could achieve on the cache test.
I'm amazed by how short and fast a sweep he uses to detect such a deep target, and how "quick" the response is. It doesn't "feel" deep to me. But perhaps that is because of the "cone" of detection with deep targets, where the mag field is strongest directly below the coil and can make a such short beep. I would think however that a slower responding filter and a slower sweep speed might have a better chance of detecting large deep targets.Originally posted by Skippy View PostI've just noticed on Gary's Detecting site that he has tested the XP Deus large coil. He ran it across the buried cache as part of his test procedure, and it gave a hint of detecting it.Here's the link:http://www.garysdetecting.co.uk/xp_deus_coil_review.htm
-SB
If your intention is to build a test for an LRL, then you would better off going to www.longrangelocators.com.Originally posted by Agraz View Post-I'm not very interested in testing detectors from above (vertical)
-if I am interested in detecting the coins to the distance (horizontal)
* only try with long range locators, may be: 20-40 meters, not thousands...
i have this 2.500 silver coins for the test (40-50kg),,, for test this i want build
a cientific locator, try develop something or buy something.
These devices are no longer discussed here in the Geotech forums.
first i check the ground looking for buried metals with two box.
Uploaded with ImageShack.us
Now I need to know your opinion to know what is the best container and depth.
wood or clay?
Originally posted by pml View PostThat's some great testing there.
I would have to disagree with that. I believe that a PI can take advantage of the fact which means higher voltage. Remember that the increase in the coin/nugget's eddy current will be about the same regardless the metal type, to within reason, because the pulse should be fast, meaning it's mostly inductive, not resistive. But when the applied voltage is removed then the coin/nugget will decay at a rate depending on the resistance of the metal.
Well, that's just PI and nothing to do with VLF's, and that's assuming the PI is tuned for the lower conducting metals such as natural gold, not coins.
Paul****************************
This post is littered with technical errors, and muddled propositions.
(1) that lower conducting materials has a faster di/dt decay time,
Correct in part, but you're not being specific....what about a target's other factors besides its conductivity or conversely, its resistance? Like physical dimensions ratio?
(2) Remember that the increase in the coin/nugget's eddy current will be about the same regardless the metal type,
ABSOLUTELLY INCORRECT: ( and self contradictory....read your own statement as in (1)
(3) because the pulse should be fast, meaning it's mostly inductive, not resistive.
What exactly are you referring to here, the TX pulse or the target's effect on the di/dt 'overshoot'?
All TX pulses are assumed as being 'fast'. (Sharp leading and trailing edges.)
Any references of inductance or resistance can only be related to the target.
(4) when the applied voltage is removed then the coin/nugget will decay at a rate depending on the resistance of the metal.
INCORRECT, due to failure to properly define the full components of ANY target
i.e.......L/R is the 1st order definition of any target such as a coin or gold nugget.
Matt.
caches in the UK are usually a wooden box that rotted away or a earthenware pot or even leather bag since rotted away .Originally posted by Geo View PostHi Carl. Good test for America but bad for Europe where there are caches 50..2500 years ago inside metallic boxes. Anyway every test is wellcome.
But a metallic box 2000 years ago inside the ground can more easy detecting than in air.
sometimes no apparent container was found as they were buried in haste ,marauding Vikings or Saxon invaders on their tales.
the odd roman silver bowl might have been used .
