Help for Anker SS60
    Originally posted by Anker
    The sensor control can be applied as in Anker -50 or any other types or size (Ring, DD, Bigfoot)
    All best.
    Hi. I mean about turns of coil. If SS60 and Anker50 have the same turns of coil.
      For sensor by diameter 39 refer to approximite:
      TX - 50-60 turns wire diameter 0,3мм
      RX - 250 turns wire diameter 0,15мм
      diameters TX / RX pertains as 2 / 1
      turns RX / CX pertains aproximately as 10 / 1
        Thanks Anker.
        The distance 60 cm for a coin 25 mm is with coil 39 cm ??
          D1...D10
          Hi Anker. I want to learn something else. I want to put 1N4148 for D1...D4 and 1N4001 for D5...D10. What are you say ??
            The Regard, Geo!
            Yes, distance 60 -63 cm of corse, to for coin 25мм in air corresponds to the head by diameter 39см. 1N4148 for D1...D4 and 1N4001 for D5...D10 - sorry, I do not know. Try.
              Thank you Anker.
              Best Regards
                I am near to finish the Anker SS-60. I must make the transmitter but i am not sure about DA1. It is a double Op.Amp so i will try with a LM747. Any idea ??:confused: :confused:
                  > LM339 is OK for 157UD2???
                  NO. LM339 is 4 comparators (LM393 - 2), 157UD2 is 2 ordinary opamps like LM358.
                    Thanks KT315.
                    I will try a LM358
                      Finito la musica but HELP
                      Hi. I finished Anker SS-60. I connected a coil that i have from an china detector to the oscilator and i tried the generator. Generator and power suply worked fine. But i must try all the detector. Anker gave me the turns for the coil at 39 cm diameter. May anyone to tell me where i can find a coil housing for a coil 39 cm ????? I don't like to make a coil 10in only for the test of SS-60. Or do you have a easy way to build a coil housing ??
                        There are some coils available in my country (BG):
                        Upload, organize and share your photos with ImageShack. Fast, reliable image hosting with albums, privacy controls, direct links and resizing.
                        I belive they are near 6-7 E a piece, not sure if they make international delivery. I can ask if you like.
                        It's a 382mm plastic coil. So not good
                        I have done something good about the coils - I've constructed coil matrix for 28sm,35sm i do not use plastic but fiber glass - much better than plastic. I do not sell them.., plus there are not good enought to do so. Just look the photos for the smaller 28sm coil.
                        I can give you ideas if you want to construct your own coil housings. It only takes time to build and the result is rather than good
                          Help for Anker SS60
                          Can someone post Schematic for Anker SS60 and PCB photo. The Web site runs at 1 KB per second !!!!! I dont have time to Wait. Thank-You. Eugene [email protected]
                            Thanks for your reply .I found a coil housing at mdetectors.com (BG). If they will not send it to me then i write you to ask about international delivery.
                              I believe they do. The coils there are 320mm. If something fails msg me, i will gladly help if i can.
