Help for Anker SS60
  • #76
    Hi nelson
    I decide design PCB for anker s60 in future.
    As I am very busy, therefore will be Wait for your PCB.
    Thank you.
    • #77
      PCB for SS-60
      Hi Geo.
      About SS-60 schematics, can you tell me what is SR1?
      Rigth now i have almost 50% ready of ss-60 schematics on livewire software and after that i just have to export it to PCB wizard. This task is very easy with this software. I also had tried eagle and Sprint layout softwares, that indeed are good for this, but a little slow if you compere them with Livewire and pcb wizard software.
      So i think that if i have enough time this weekend, may be pcb for ss-60 will be ready very soon.
      Best regards
      Nelson
      PD: when ready, i ll post my pcb here, with the intention to review it by others and of course to give a try on homebrew metal detector.
      Hi Nelson.
      Look at the schematic that i have attached here at this page.I have replaced all the russian components with european. If any problem, write me.
      • #78
        Hi Nelson.
        SR1 is a 7809 voltage regulator.
        But be careful........ 7809... not 78L09 because the current is high.
        • #79
          SS-60 schematic and pcb
          Hi Geo and thanks for the information.
          Now i uploading the schematic of Anker SS-60, made on livewire software. So if you or anyonoe can check this, please let me know.
          I also had tried to build the pcb on PCB Wizard, but this shows that i need at least a 23 by 23 cms pcb (too big).
          I also xan generate a gerber file, but im not so skilly with this, so if anyone can help on building the pcb, will be very nice.
          I hope this small contribution, can help us to get a good one side pcb.
          Best regards
          Nelson
          Hi Nelson.
          • #80
            Hi my friend, Nelson
            Thank you for it, but I don’t have livewire software and
            I saw only schematic in .gif format and another file
            Is ss60.lvw .
            Where is ss60 pcb? Please convert .lvw to .pdf.
            Best regards.
            • #81
              Hi Nelson.
              You can make 2 pcbs 12x10 cm and will be ok.
              I made the ss60 on 2 general purpose boards 10x15cm or 10 x 16 cm (i don't remember exactly), but there is enough free space.
              • #82
                Yes Geo, i ll try to split it on two pcb´s. Thi will demand a little more time. So by now i need anyone that can check this schematic, so i ll try to convert it to pdf, gif, jpeg or similar format.
                Nelson
                Hi Nelson.
                • #83
                  Hi Nelson
                  Sorry for me but now i have not time to check the schematic
                  • #84
                    groza or Thunder--is much better , had good ground rejection!!!two-tone sound!good diskrimination!
                    I have Thunder 4Gt-with 28cm. DD coil --- 25mm coil--good signal to 45cm on air,and near 28-30cm. in ground(self testing)
                    • #85
                      http://ciklon.com.ua/pix/schems/
                      Good results
                      • #86
                        Hi unregistered
                        Are you also have anker ss 60 ?
                        What’s you said ,Is it result of comparison between two, anker ss60 and thunder 4gt?
                        • #87
                          Help for Anker SS60
                          Hello , Anybody know a little more about this Mini-Power schematic ??? Depth Tests in Soil , or air ??? Also is Ciklon the same builder of the Anker and Thunder 3 ,4 ,5 ??? Thank-You..................Eugene
