We see the ground balance feature in a normal detector, it usually comes at 90 as standard. When we hold a target and pass it through the air test, we see ID=52 as an example. When you change the ground balance and pass the target again, the id does not change.
Could you briefly share what ground balancing actually does?
Note: We talk about vlf metal detectors
