Newbie
  • Newbie
    Anyone who can help with a Garrett Ace 250 problem? It has been great for the past few years and just went to only being able to detect coins at 2" in air. Detects nothing at 5" regardless of size. Been told it is probably the coil and checked the resistances. Told they were within spec. Have a digital scope, etc. Anyone suggest any tests? Detect alone and can not borrow a coil to check by substitution.
    Click image for larger version  Name:	image.png Views:	0 Size:	981.7 KB ID:	426157​show what you have on oscilloscope, U8 pin 6, U2 pin 5, U12 pin 1 & 4.
      Thanks Pito. Found the op amp, OP 37 and with no metal presnt it is showing 6.65KHz pk-pk 340mV. With metal pk-pk 6.5V, about same frequency. U2 and U12 appear to be different (LMC60, LM396?) but will trace through crt to check - just off to work.
        show PCB picture
        6.65KHz pk-pk 340mV. With metal pk-pk 6.5V, = OK,
        it is sine wave ?
        4016, pin 5, 6 ?
        KT1, KT10 ?
          It was a sine wave, it clipped at 6.5V. Noticed that the presence of metal only altered the waveform at short distances, less than 3". Just back from work and I intend to scope the crt at the points you suggested. I attach a photo of the pcb. Once again, thanks for the help.
            4016 pin 6 sine wave (distorted, more like a rounded square wave) pk-pk 880mV 6.65kHz, with metal more like noise
            4016 pin 5 noise only, with metal, no change
            KT1 sine wave pk-pk 260mV 6.8kHz, with metal 6.6V 6.8KHz square wave
            KT10sine wave pk-pk 220mV 6.8kHz, with metal 6.6V 6.8kHz square wave
              U3 pin #1 = 8V ?
              416 ,5,6 = 8V square wave, shifted 90 degrees
              KT1, KT10 = similar to this
              Click image for larger version  Name:	image.png Views:	0 Size:	42.4 KB ID:	426202
              bottom line, green pulses
              Click image for larger version  Name:	image.png Views:	0 Size:	114.0 KB ID:	426203
              U8 pin #8 = 8V ?
              ​​Click image for larger version
                U3 pin 1 8Vdc
                4016
                pin 5 just noise, with or without metal
                pin 6 noise without metal, distorted square wave pk-pk 6.8V, 6.8kHz with metal
                KT1 and Kt10 as before, sine wave without metal, square wave with but distorted on KT10 and metal vitually touching coil.
                Any thoughts Pito regards coil or pcb?
                Thanks, Jerry
                  Any thoughts Pito regards coil or pcb? = let see the results mentioned below tests
                  For now without coil.
                  U2 pin #6 = 8V DC ?
                  Pin #5 = square wave 8V?
                  U12, pin1, 7 = square wave 8V?
                  pin 8 = 8V DC ?
                  U8 pin #8 DC voltage ?
                    Without coil, U2 and U12 were just noise at pins indicated. U8 pin 8 was 7.4V dc
                      U2 pin 8 = 8V DC = U2 and U12 were just noise at pins indicated = ?
                      with coil C31 = ?
                        Without coil
                        U2 pin 6 8V dc, pin 5 noise, pin 8 1.5Vdc
                        With coil
                        C31 sine wave/pulse pk-pk 31.8V 6.65kHz
                        Pins described as noise were mainly 50Hz (mains power)
                          C31 sine wave/pulse pk-pk 31.8V 6.65kHz = perfect , Tx coil ok
                          C24 ,no metal close to the coil = ?
                          U8, pin 6, no metal close to the coil = ?
                          C38 = ?
                          U12;
                          pin 8 = 8V DC ?
                          pin 3, 6 = sine ?
                          pin 1,7 = square wave 8V ?
                            C24 noise
                            U8 pin 6 noise
                            U12
                            pin 3 sine wave 3.4V pk-p k
                            pin 6 sine wave 6V pk-pk
                            pin1 noise
                            pin7 sq wave 3V pk-pk
                            pin 8 8V dc
                            Having problems finding C38, my eyes not too good! All waveforms at about 6.65kHz.
                              C24 noise = with metal close to the coil ?
                              U8 pin 6 noise =with metal close to the coil ?
                              U12
                              pin 3 sine wave 3.4V pk-p k = not perfect but ok
                              pin 6 sine wave 6V pk-pk = not perfect but ok
                              pin1 noise = not good, should be the same as on pin 7
                              pin7 sq wave 3V pk-pk = not perfect but ok
                              pin 8 8V dc = ok
                              U12
                              pin 2, 5 ?
                              U8
                              pin 3 DC = ?
                              pin 7 DC = ?
                              U9
                              pin 5 = resistance to the ground ?
                              pin 6 = resistance to the ground ?
                              C38
                              Click image for larger version  Name:	image.png Views:	0 Size:	6.2 KB ID:	426262
